Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Verbatim store-n-go 8GB usb drive is not recognized by windows XP?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
Contact Verbatim for a solution, these USB flash drives have lifetime warranties!
Posted on Oct 25, 2013
5 Suggested Answers
anaesarora
  • 180 Answers
SOURCE: Verbatim USB 8GB file copy problem
ITS virus problem which is playing with the inf file of the usb drive.
also another possibility is 1) the usb port ihas loose connections and disconnects i between drive sensing
2) certain 8 gb drives go back to a capacity of 2 gb drive if one formats it accidentally .
Posted on Sep 19, 2009
Testimonial: "Spot on!.. I found your answer match my further investigation.. Thanks again for professional work and response..I will highly recommend site."
  • 20 Answers
SOURCE: My laptop does not recognize my verbatim 8gb flash drive
go to Control Panel, then to System Mgr and then Devices. Check to see if all are marked with +s. You probably have a - in that area. Click on the minus and see what it says. You may need to add a driver or reinistall the flash drive.
Posted on Oct 25, 2009
SOURCE: Verbatim portable hard drive not recognized by XP - works in 2000
Try it is different USB port of your PC. It worked for me.
Farhan
Posted on Nov 10, 2009
  • 1623 Answers
SOURCE: USB portable Verbatim Acclaim 320gb
the power requirements of the hard drive are too much to run it from the laptop, remove any other usb devices and you will find that it works
Posted on Mar 16, 2011
Verbatim store n go usb flash drive 8 gb device not recognized
My Verbatim Sto N Go 8GB USB Flash Drive does not work in any port, in any computer. When I plug it in, the "Device is not recognized" error comes up. When I click on it, and the Unknown Device Properties comes up, the device status reads: "Currently, this hardware device is not connected to the computer. (Code 45)
To fix this problem, reconnect this hardware device to the computer."
The driver details read:
Provider: Advanced Micro Devices
File Version: 1.0.11.82 built by: WinDDK
Digital Signer: Microsoft Windows Hardware Compatibility
This is the 2nd drive of this same brand that quit working within 6 months. I have MONTHS of work on files in this drive, and would hate to have to redo all that work! I was real careful after the first one went bad to use the eject button when removing it from my computer. But I am thinking the last time I clicked the eject button, it froze, so I just pulled it out without the message coming up. Hopefully there is someway to get the computer to recognize this drive again???
Sep 26, 2012 | Verbatim ® Store `n` Go USB Flash Drive,...
Please insert disk
Insert the disc that came with it ( if no disc came with it then it should not need one.) If it still insists it needs a disc go the verbatim website and go to the drivers/software/downloads page, and select the model of the pendrive and download the appropriate drivers ( your operating system etc XP or windows 7)
Plug it into the usb port and go to 'my computer' there you will see the drive most likely named verbatim, double click to open it.
Then open a new window and find the file you would like to transfer, simply click on it and drag and drop it into the usb drives window and wait for the file transfer to finish.
Jan 06, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
NOT RECONISING THE PEN DRIVE-Verbatim ® Store
try a usb port on the back of the computer, if not the drive could be faulty
Jan 03, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
Verbatim 8GB Store-an-go just went dead between uses. Computer does not even register a drive. Is this a loose connection.
have you tried it on another computer? There really are not connectors to get "loose" but unfortunately sometimes the drives do die. I would try is on another computer (windows XP or newer)
If it does not show up on another computer than chalk it up to experience. There are restoration services but they are very pricey. If you pursue this expect to pay $300.00 plus for recovery.
Sorry for your loss.
Nov 29, 2010 | Verbatim ® Store `n` Go USB Flash Drive,...
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Oct 25, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Sep 18, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
USB Flash drive suddenly not recognized in WinXP
Ive included here a link that helped me fix a problem with my flash drive that was giving the same problems. perhaps you could take a look at it.
http://www.hat.net/geeky/node/221
Oct 27, 2008 | Computers & Internet
Verbatim Store n go 4 GB USB HD Drive
IF IT HAS U3, YOU NEED WINDOWS XP...AT LEAST TO ADD THE VISTA UPDATE FROM http://www.verbatim.com/downloads/U3/u3updater_verbatim_us.exe
IF NOT THEN YOUR DRIVE MIGHT BE DEFECTIVE OR ONE THAT YOUR OPERATING SYSTEM CANNOT USE
Feb 21, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
167 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
