Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Start up problem
I start up dell dimension 8200 it is okay thru dell start screen but goes black when entering windows
    Genius:
  • 2,785 Answers
Try to load in safe mode if the problem persists than you have to repair or reinstall the OS
Posted on May 05, 2008
What is the maximum ram capacity of dimension 8200 motherboard
2 gygabytoes are usually the max, you could upgrade the OS to maybe Windows XP 64 bit, but this isn't worth it in such an olde machine! Throw it out and get yourself an ASUS laptop with Windows 7 64-bit, a solid state HD and 4 or more gigabytes of ram instead!.
http://www.crucial.com/upgrade/Dell-memory/Dimension+%2F+Dimension+XPS/Dimension+8200+Series+%28400MHz+FSB%29-upgrades.html
Mar 16, 2013 | Dell Dimension 8200 AUD System Board...
Plug & Play Configuration Error
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
hope this helps
Nov 30, 2011 | Dell Dimension 8200 PC Desktop
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
When i turn my dimension 8200 on it will not boot i keep getting the black screen with the safe mode option but if i choose the start windows normally option it goes to the blue screen telling me to check...
Your operating system or Master Boot Record is corrupt. Which version of windows are you using?
It may be possible to repair the problem with your windows disk. Boot from the Windows disk but make sure you read the instructions for windows repair carefully because some options will format your hard drive.
To rescue the data here are some things I do:
Make a boot disk with USB support and transfer the contents of your drive ton an external harddrive. Or, you could place your hard drive in another computer as a slave drive and retrieve your files that way.
Mar 28, 2010 | Dell Dimension 8200 PC Desktop
When i turn my dimension 8200 on it will not boot i keep getting the black screen with the safe mode option but no matter option i choose it aslways comes back to the black screen
if you have the windows xp disk, boot from it by pressing F12 upon turning on your computer. press 'R' to choose recovery console. you might be asked which windows installation you want to start, just press 1. when you see the console, enter the command 'fixboot' without the quotes. then type exit to restart your computer. hope it helps.
Mar 14, 2010 | Dell Dimension 8200 PC Desktop
My Dell Dimension 8200 PC keeps re booting itself once it gets to the home page. i cant even hit the start button cause it restarts itself that fast! please help
As soon as u see the black screen...hit F8 repeatedly to get it into Safe Mode.....then go to system restore and reboot/restore system back on a saved day. Then run your virus protection and scan for malware. This should get you back online. You may need a full system scan to locate the effected DLL's anmd killl off your intruder.
Jun 23, 2009 | Dell Dimension 8200 PC Desktop
I have a desktop dimension 6400 and it goes to black screen i pressed f12 and went thru every thing and pressed enter it goes back to black screen
Sounds like you are having a boot issue with the hard drive.
Try booting to your XP CD from the F12 menu and running CHKDSK /F from recovery console
Jan 14, 2009 | Dell Inspiron 6400 Notebook
Dell Dimension Desktop 8200
Dear Sir:
This could be due to bad hard drive or file system damage if the below steps doesn't work please contact the dell support for hard drive replacement if you computer is in warranty.
If this is the case, restart the computer to the Recovery Console, and then use the chkdsk /r command to repair the volume. After you repair the volume, check your hardware to isolate the cause of the file system damage.
To do this, follow these steps:
1. Start your computer by using the Windows startup disks, or with the Windows installation disk if your computer can start from the CD drive. 2. When the Welcome to Setup screen appears, press R to select the repair option. 3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console. 4. Type the administrator password when you are prompted to do this.
Note If no administrator password exists, press ENTER. 5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER. 6. At the command prompt, type exit, and then press ENTER to restart your computer. If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command.
Let me know if you need any further assistance and if you have a moment to accept and rate the solution I would greatly appreciate it.
Thanks,
Mohammed.
Aug 22, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
107 people viewed this question
Alun Cox
