Question about HP Pavilion dv6000z Notebook
My hp dv does not boot. it seems to be charging battery when it is connected but cannot boot without the battery. It does not show power or boot when on power alone.
  • 229 Answers
PROBLEM:
bad charging module on motherboard.
SOLUTION :
Check if your charger brick is working, if are OK, you must send your laptop to a shop for fix the motherboard.
Please rate my solution
Posted on Aug 24, 2010
IPhone 3GS battery replaced, connected to itunes via USB cable and synced, battery percentage indicator showed a power plug didn't start charging. Charger removed and over night the battery seemed to have...
Is the replacement battery an original equipment battery? I bought an aftermarket battery for my Samsung and the phone will not recognize the battery even though the specs are identical. Nice trick by Samsung. See if I ever buy another product of theirs again. Anyhow try putting the old battery back in and see if it will function while plugged in. Otherwise head to the phone store.
Nov 01, 2013 | Cell Phones
Hp pavilion dv 2023 will not start
check power supply is connected
Check connections inside desktop
If the computer is not turning on at all "booting", it may have short circited
Aug 18, 2008 | HP Computers & Internet
,my lg p970 cannot boot. it simply shows lg logo and flickering lights on menu buttons...what seems to be the problem?
Hi let me introduce my self, I am (BRYAN).
to solve this problem. Remove battery from phone keep aside then connect charger to phone and power on let the phone display a battery with an ! mark over it then remove charger and replace battery and switch on. You are done. (bryan.ryle@gmail.com)
Nov 29, 2012 | LG Optimus Black Smartphone
Computer will not turn on. Battery is fully charged.
this is how i did one the other day and it booted right up, do not turn your laptop on, remove the battery and do not have your ac adapter plugged up to the computer, after you have took the battery out and unplugged the power cord, hold the power button down for 10 seconds, this releases all internal power from the motherboard, after this step is completed do not put your battery back in, plug your ac adapter up to your computer and push the power button and it should boot up. The Hp DV series computers have a recall on alot of the batteries, so you might want to look that up on the HP website.
Nov 07, 2010 | HP Pavilion dv6000z Notebook
Battery not charging
Hi. I would suggest that you powerdrain your computer might fix this. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. If this doesnt work try to powerdrain again the laptop then just use the ac adapter to turn on your computer and that is without the battery. If this one work consider replacing the battery or you call the tech support dept of HP if you are still under warranty so that they would replace it with a new battery without any charge. Hope this helps.
Jun 03, 2010 | HP G60-120US Laptop
No video, no boot. continually cycles trying to boot
Well, if you've already checked all the necessary hardware and they all check out, it seems the only problem is the motherboard.
Actually, the more recent DV#### models from HP have had hardware defects, and they have offered to repair these computers if they show any symptoms of defect.
The chipset product line coming from ASUS was faulty, and have caused hardware failures such as this.
Call customer support for HP and have them schedule a repair for your laptop. They should repair it free of charge, whether the warranty expires or not.
Hope that helps.
Jan 14, 2010 | HP Pavilion dv9000z Notebook
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | Computers & Internet
Black screen instead of desktop boot screen
The issue can be with any Operating System files that might have gone Curropted.
I recommend you to try pressing the Ctrl + Shift + Esc keys after you are sure that the Operating System is booted which should get you the Task Manager window.
In this, click on File > New Task(Run) and enter Explorer.exe in the field and click on OK.
This should get you the Windows Explorer.
However, I recommend you to either try reinstalling the Operating System in your Notebook to factory settings or Repair the Operating System using Windows XP disk if you have to repair the curropted files.
Find the instructions to Repair or Reinstall the Operating System in your Notebook from the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00681978&dlc=en
Make sure that you take a backup of all the files before proceeding with reinstalling the Operating System as it will erase all the content in the hard drive if you are using the Disks provided by HP.
If you are not able to see any LDEs blinking in the Notebook when you press the Power Button, the issue can be due to Static Charges which might be preventing the Notebook from starting up. In situations like this, you need to try the steps listed below :
1. Disconnect the AC Adapter.
2. Remove the Battery. Note : Please see that there are no external devices or cables connected to the Notebook. 3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now. 5. Turn on the Notebook power.
Hope this helps....
Nov 03, 2008 | HP Pavilion dv6000z Notebook
Pavillion DV1000 will not boot
may be two things 1. your powersupply unit is gone or 2. your motherboard
Jun 11, 2008 | Computers & Internet
Battery/configuration/
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
well, the issue seems to be with Battery , it is not working properly any more. or it could be an issue with Battery drivers in PC.
To isolate the issue, I recommend you to try below steps. This will resolve the issue .
Step 1: Connect Battery and Also AC power adapter, try to charge the Battery for around 6 hours. Make sure that notebook is idle for 6 hours, do not try to run any application . Just let notebook be ON for 6 hours with AC power with Battery in, so that battery gets charged up.
Step 2 : Once if you are done with 6 hours of Charge, now disconnect the AC Power. Restart PC and let the PC run on Battery only. Check out how much time PC is able to run on battery. If PC powers ON properly with battery and runs around 40 minutes then it confirms that Battery is fine else if PC do not startup properly or if it works less than around 30 minutes on battery then it confirms that it is an issue with Battery. If found fault with battery then try step 3 process.
Step 3 :  To check Health of Battery
Please open below link in the new Internet Explorer. Copy and Paste the link at the address bar  and then click GO. This will open a web page that titles as " HP Notebook PCs -  Checking the Status of the Battery in Windows XP"
Link :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&product=468789&rule=44465&lang=en&docname=c00035864#c00035864_doc
Once if you open web page, please perform the steps that are mentioned in web page as appropriate to your issue. I hope that this should resolve the issue.
If you need any further assistance on the issue, please mail me at thumuvikram@rediffmail.com I'll be glad to help you.
Bye...
Oct 27, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
