Question about AEG Dishwashers
Aeg favorite 911n81-8f.......need new cutlery holder and the wheels that slide on the runner for the top shelf need replacing, can you help?
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
  • 20 Answers
SOURCE: I need an manual in english for the AEG Favorit
try here. http://www.serviceforce.co.uk/pdf_search.asp
Posted on Jan 21, 2010
Macmarkus
  • 2605 Answers
SOURCE: need top left shelf runner. fell to bits
Hello, This is common with Asko after a period of use, the heat makes the plastic pieces brittle over time or amount of use. If you still have the ball bearings good, ( 4 per side ) keep them and you'll only need to replace the gray plastic pieces known as the guide rail "ball holders". If you don't have all the ball bearings, get yourself a telescopic magnet and make sure one or more hasn't found it's way into the wash or drain pump as they have a tendency to do so. This obviously can and will cause serious problems because the wash & drain impellers are plastic...steel vs. plastic = not good. The Asko part number for the holder is 8058638 and should come as individuals so order 2, one for each side. The ball bearings are # 8057977 and as mentioned, require 4 on each rail/side. As for where ? I use Amre Supply, so you could check out their on-line availability at amresupply.com if you'd like. Hope that helps solve your problem. Thank you for coming to "fixya" for your solution. Let me know if I can assist you further and good luck. macmarkus :)
Posted on Apr 05, 2010
mastermaid
  • 502 Answers
SOURCE: AEG FAVORIT 443 Manual I need a manual. How to
Hi, I found the Favorit 443 manual here
Posted on Aug 19, 2011
There are holes of my cutlery holder in my g164 and i want to buy a new one
Hope you have the correct part number for the cutlery basket. The dishwasher model number g164 does not seem to be complete.
The cutlery basket is available on an online parts shop.
http://www.appliancezone.com/ShowProduct.aspx?ID=75650
The business is based in US but ships worldwide.
Apr 16, 2014 | Bosch 491430 - BASKET-CUTLERY
New AEG dishwasher wont fit in existing space that housed our old Favorit 44050 VI
The space underneath the dishwasher, or cabinets, is referred to as the kick space. It is where your toes fit under the edge of a counter and they are typical of cabinets and dishwashers alike. You should not expect a wood trim piece to fit underneath the dishwasher and not all dishwashers will accommodate one. It is fair to say that all dishwashers will come complete with a trim piece to cover this area, since some have venting and others do not; some have a door that extends down further and some do not. Generally speaking the variation people concern themselves with is in dishwasher's width and not in the door configuration. So having said and in consideration of your (assumed) desire to retain the wood trim, I suggest you retool the wood trim piece to work/fit with the dishwasher you decide you want. This is what I did rather than use the provided black metal panel. I have attached photos.
d8c6be34-1c2a-482c-8f06-f609e72b619c.jpg 9cc1da12-62a1-4b9c-9bc2-5a2b06e4845b.jpg
Mar 11, 2014 | AEG 24 in. Favorit 44050 Built-in...
AEG favorit 40850 dishwasher does not clean properly - help
under the top shelf or in the top of the machine is the water rotor. remove this and ensure none of the holes are blocked, also ensure your macine is not running on 1/2 half load as this may only activate the bottom. it should be set to full load to use both. if rotor bloackage is the problem use somthing to clear it. and also check the bottom one. also remove and clean the inner filter as debris may have got past it and getting pumped to your rotors.
I hope this was useful
Feb 15, 2013 | AEG 24 in. Favorit 40850 Free-standing...
AEG D2100-4 , THE TOP GRILL HAS FALLEN DOWN AND THE RETAINING SCREWS WONTS GO BACK ANY IDEAS THANKS
Hi the spare part solution is to replace the oven liner. not economic and difficult to do. If engneering minded you can make a long slide clip i have made some out of an old oven shelf grid.forming a shape similar to a tent peg in shape and size and sliding it horizontally through the grill retainining bracket and hole in the oven liner. not easy to explain this but it works on aeg bosch and neff ovens with the same fault.
Nov 09, 2010 | AEG D2100-4 Electric Double Oven
Dyson dc11 replacing motor
DYSON DC-11 MOTOR REPLACEMENT
1. Remove dirt cylinders as normal
2. Using large flat screwdriver, remove airway splitter and hose
3. Undo 6 Torx screws from top and one at the back under tool holder
(Note that 2 front screws are shorter)
4. Make sure the screws are completely withdrawn
5. From the back, withdraw tool holder section
6. Unhook and withdraw hose holder section
7. Place large flat screwdriver behind the wheels and forcefully snap them off
8. Remove 2 more screws under each wheel
9. Cover now lifts off
10. Motor pod is now visible. Remove its 4 screws and lift its lid
11. Motor can now be lifted out. Disconnect its 2 wires
12. Remove the rubber base and transfer to the new motor
13. Connect wires, Red to Brown (Live) and Black to Blue (Neutral)
14. Make sure motor is correctly fits on its alignment studs in the pod and replace its cover and 4 screws
15. Replace top cover of machine, and the 4 screws under the wheels, but no other screws yet
16. Turn machine on its side and hammer each wheel back on - take care that no fingers are under wheels while doing this
17. Stretch and snap hose holder back into position
18. Slide tool holder forward into position
19. Replace the 6 screws into top section, and one into tool holder section
20. Replace filters, airway splitter and dirt cylinders, and the job is complete :D
May 22, 2010 | Dyson DC11 All Floors Bagless Canister...
Need top left shelf runner. fell to bits
Apr 05, 2010 | Asko D1876 Dishwasher
Dishwashers Logo
69 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
