Question about Gaiam Inversion Table
How do you attach the spring in the foot assembly
How do i get the walking foot to glide onto the sewing machine
It sounds like you are trying to attach a walking foot to your machine. Usually when you install your waling foot the needle clamp screw pushes against the lever. This lever is spring loaded. To avoid fighting the spring you can lower the needle into the hole on the walking foot and then attach the foot to the ankle.
Mar 07, 2016 | Bernina Sewing Machines
How do I fix the foot pedal assembly for the handle release on shark vacuums?
You should call cust service. Call may still replace it.
Aug 04, 2014 | Shark Vacuums
I need to reattach the spring to my walking foot on my 1475 cd pfaff sewing machine if you have pics that would be very helpful, thanks
I don't have that mwchine any longer but I think you might get an answer on Pfafftalk.com for this question
Jul 27, 2014 | PfaFF Sewing Machines
Recliner foot rest bolt broke and spring came off
looking for two small springs that go in the foot lift section of a lazy boy recliner. these springs allow you to raise the foot lift to different positions. these are very small springs and attach to each side of two small drum types.
Mar 22, 2013 | Lazy Boy La-Z-Boy Power Lift Recliner...
Husqvarna rose tried to run it and the pressure foot light comes flashing on and will not run. yes the presser foot is in the down position
There is a safety switch underneath the presser foot lever, its tucked away in the body cavity and its tough to see. The switch is operated by a metal spring that turns the switch off and on according to the presser foot lifter position. the spring, which kinda looks like a fork, gets compressed each time you lift the presser foot. It wears and works intermitantly. A dealer is the only solution, the back needs to come of, and its a dang tough job to replace without damaging the replacement spring.
The other thing it could be is a jammed check spring inside the tension assembly, again its a tough job as the auto tension assembly must be removed, along with the winder and loosening of the main board.
derek
Jan 15, 2011 | Husqvarna Rose
How do I assemble a Bassett crib model 5096-0505? I think I have all the parts. this includes a headboard, footboard, spring mattress support, mattress, two long iron rail support brackets, two sides, four...
where's the manual?
you can assemble it immediately!
have u lost the manual?
you can find the manual here:
Please use the form below to send us an email.
Infant furniture questions to juvenile@bassettfurniture.com
hope you could come to this sites there are many related manners all about mattress:
http://www.bestmattressreviews.com
Dec 06, 2009 | Bassett Mission Crib
I have a 94 jeep wrangler front left axle seal bad. I took the left side apart and not sure how to get the seal back in. Do I need to open the inspection cover on the diff. and take the gears out?
Rear Axle Notes
  1. Raise and support vehicle.
  2. Remove rear wheels.
  3. Scribe alignment marks on propeller shaft and axle for proper assembly, then disconnect propeller shaft from axle.
  4. Disconnect the track bar from axle mounting bracket.
  5. Disconnect parking brake cable at equalizer.
  6. Disconnect shock absorbers at axle tubes.
  7. Disconnect hydraulic brake hose at rear axle Tee-fitting, then tape ends of hose and fitting to prevent contamination.
  8. Disconnect axle vent tube from axle.
  9. Remove U-bolts and tie plates.
  10. Loosen spring mounting bolts.
  11. If equipped, disconnect ABS wiring connections at axle.
  12. Support axle with suitable jack.
  13. Remove spring-to-shackle attaching bolts and lower spring to the floor.
  14. Remove axle assembly.
  15. Reverse procedure to install.
Front Axle Notes
  1. Raise and support vehicle at frame behind front springs.
  2. Remove front wheels.
  3. Scribe alignment marks on propeller shaft and axle yoke for proper assembly, then disconnect propeller shaft at axle yoke.
  4. Disconnect connecting rod at steering knuckles.
  5. Disconnect shock absorbers at axle housing.
  6. Remove stabilizer bar connecting links to spring tie plates attaching bolts, if equipped.
  7. Disconnect breather tube at axle housing.
  8. Disconnect stabilizer bar link bolts at spring clips.
  9. Remove disc brake calipers, rotors and brake shields.
  10. Remove U-bolts and tie plates.
  11. Support axle assembly with suitable jack to relieve spring tension.
  12. Loosen rear spring shackle to spring attaching bolts.
  13. Remove front spring shackle to spring attaching bolts and lower spring to floor.
  14. Remove axle from under vehicle.
Jul 21, 2009 | 1994 Jeep Wrangler
Gaiam Inversion Table Logo
27 people viewed this question
Top Gaiam Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Gaiam Exercise and Fitnes Expert? Answer questions, earn points and help others
