Question about Whirlpool 17.6 cu. ft. Top-Freezer Refrigerator w/ Factory-Installed Icemaker
It was leaking water- I see you have a few other people that experienced that. Then it sounded like it would click off then on, off then on, etc. That happened a couple times, but it would stop eventually and seemed fine. Last time it happened, after it had stopped, the refrigerator stopped cooling, but the freezer is beyond frozen. There's frost everywhere, when there wasn't b/f the bottom portion stopped working. As far as I can tell there is only one temp control in the bottom portion, which we turned up to 5 b/c like I said it's barely cooling. Could something from the freezer to the bottom portion be frozen preventing the cooling from reaching the bottom?
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Leaking Krups XP4030 Espresso Machine
i think it is better if you try contacting ur service centre
Jun 28, 2008 | Krups XP4030 Espresso Machine
No Power after loud pop sound, is the power switch bad?
It is probably a bigger problem than the switch. If you are not experienced in working on electric appliances, you need to take it in to the repair shop.
May 23, 2015 | Nuova Simonelli Premier Maxi Espresso...
Why is my 2000 impala is overheating
Hi there, Overheating can be caused by a few things.Thermostat,sticking Water pump impella worn or bearings,
clogged outer radiator core[dirt etc] loss of water or coolant,dirty inner radiator core,Head gasket leaking gasses into cooling system,binding brakes,semi clogged muffler or engine radiator hoses no good and gone soft and being sucked in ,etc etc
May 22, 2014 | 2000 Chevrolet Impala
Popping/clicking noise
for window type ac, it must be positioned on level, to avoid flexing it's case.
Jun 04, 2013 | Haier Heating & Cooling
I was driven my car it started over heating and died. Startes for a few minutes and then dies.
it sounds very much like you have a blown head gasket it would be best to get the engine cooling system pressure tested thats if there are no visible water leaks ie.hose pipes,radiator etc
Mar 19, 2012 | Heating & Cooling
Smeg SA663 X1. It starts and runs water into the base, then hums and no action. If I move the dial around the water then emtpties out, refills, opens the powder door etc. Just no washing action. How do I...
Hello, if you have a leak within the base water would go in and then it would activate the drain pump which also would not allow the washing motor to activate due to the leak. Also if the heater in the unit is not working as well the unit would let water go into the machine and then stop as well the wash motor would not activate due to the heater being at fault. Click this link this is a simular situation as well to what you are experiencing with your dishwasher http://www.ukwhitegoods.co.uk/forumsphpbb3/viewtopic.php?f=33&t=46405 if you have any questions message me back check the float switch and the heater is one of the first things that you would look at as the problem area in the machine. I await your reply Thanks
Rick
Sep 24, 2011 | Dishwashers
Hi, I have Gigabyte MA78GM-US2H mother board ver 1.0. From past few days I am experiencing some issues with the sound clarity, I have tried different head phones and speakers but i cant fix it. i even...
sounds like your sound card is probably going bad. you should likely have some available PCI slots on that motherboard. You can purchase a cheap replacement like the one below:
http://www.newegg.com/Product/Product.aspx?Item=N82E16829111003&cm_re=pci_sound_card-_-29-111-003-_-Product
Then just install it and its drivers. Go into Control panel >> system >> device manager >> sound, video and game controllers etc... and disable the onboard one. You can do so by Right clicking on the old one and clicking disable. This will prevent any conflicts.
This should solve your problem.
Feb 05, 2011 | Gigabyte GA-MA78GM-US2H Motherboard
Indicator lights with high pitched squealing sounds.
check the alternator drive belt,it may be loose and squealing.
the alternator itself could be also making a noise.
start the car with the hood open and listen to it.
look if the belt is cracked,loose or wet from oil or water etc.
things like thermostat housings leaking coolant can cause something like that.
Sep 14, 2009 | 1999 Honda Accord
2001 cadillac deville, overheats without loss of coolant
First, provided their are no visible coolant leaks and/or loss of coolant with no signs of leaks, I would thoroughly flush cooling system and replace coolant, then check and/or replace thermostat (you can place thermostat in boiling water to check for proper function), if you have tried these 2 steps and still are experiencing overheating you may need to replace your water pump which can be a tricky job if you're unfamiliar and try to do it yourself, however, I could walk you through it if necessary. Also visually check your radiator hoses for bulges, wear ,etc along with heater hoses etc. You may want to also check radiator fins to see if they are dirty/obstructed and clean if necessary. Let me know if I can assist you further and how it works out
Aug 30, 2009 | 2001 Cadillac DeVille
Whirlpool 17.6 cu. ft. Top-Freezer Refrigerator w/ Factory-Installed Icemaker Logo
113 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
