Question about Smart Technologies SMART Board 560 (SB560)
When trying to write a straight line, the ink goes up and down. When using the arrow and moving a window, the window vibrates up and down.
Sounds like a grounding issue. Check to see if there are nylon washers on the mounting screws at the bottom. You have to remove the pen tray first. If they are there, contact your reseller. You might have a defective board.
Posted on Nov 03, 2010
Infocus 3916 Projector goes in and out of focus. It is a little less than 2 years old. Any suggestions for a solution?
Many of these projectors have a manual focus, and an auto focus. Make sure the auto focus is turned off in the menu options.
Then make sure the manual focus is not moving on it's own from vibration of the cooling fan. You can check this by manually focusing the projector, then taking a marker and marking a line on the focus wheels. If the projector goes out of focus, check the line you made and see if it has moved, if so. Your projector is going out of focus from vibration of the cooling fan, or the surrounding environment.
If your projector is mounted to the ceiling you can add a couple of rubber washers between the projector and the mounting bracket to cut down on vibration.
If your projector is sitting on a desk / table / ground, you can use foam padding to keep it from vibrating.
another solutions would be to temporarily tape the adjusting knobs while the projector is in use.
If your projector has a protective cap that is put on the lens when not in use, this will also push the lens out of focus, and will need to be re-adjusted each use.
Nov 20, 2014 | InFocus Office Equipment & Supplies
Renault Traffic 1998- Front passenger side tyre had a vibrating sound thats comes n goes when moving in straight line. It sounds like the brake is slightly on. The vibration stops when cornering.
If your brake is not releasing you could have a stuck caliper. What I would try first though is the brake hose going to the caliper. As the hose gets older the hose walls tend to break down and weaken so they collapse when the pressure releases not allowing the fluid to go back.
Mar 07, 2012 | Cars & Trucks
About shortcuts of keyboarding
Alt + F File menu options in current program. Alt + E Edit options in current program F1 Universal Help in almost every Windows program. Ctrl + A Select all text. Ctrl + X Cut selected item. Shift + Del Cut selected item. Ctrl + C Copy selected item. Ctrl + Ins Copy selected item Ctrl + V Paste Shift + Ins Paste Home Goes to beginning of current line. Ctrl + Home Goes to beginning of document. End Goes to end of current line. Ctrl + End Goes to end of document. Shift + Home Highlights from current position to beginning of line. Shift + End Highlights from current position to end of line. Ctrl + Left arrow Moves one word to the left at a time. Ctrl + Right arrow Moves one word to the right at a time.
Jun 19, 2011 | Computers & Internet
How do i install new cartridges into my tx printer first time user never changed before
With the printer on but not busy (flashing light), open the scanner unit. (Lift the scanner until the bracket on the right locks.)
If the cartridges are completely expended:
Press the Stop button on the printer, the print head should move to line the expended cartridge with the empty ink mark. Press Stop again and the next empty cartridge should line up with the mark. Continue to press Stop until the print head moves to the cartridge replacement location (after noting which cartridges need to be replaced).
One cartridge at a time, shake the new cartridge 5 times before opening the package.
Remove the new cartridge from the packaging and remove the yellow tape from the cartridge. Be careful not to damage the hooks on the side of the cartridge and do not touch the green IC chip. Leave the transparent seal in place.
Squeeze the tab at the back of the cartridge you want to replace and then lift the cartridge up. Then put the new cartridge straight into that slot and press down until it clicks.
Repeat this for all empty cartridges. Then close the scanner unit and press Stop. Wait until the light stops flashing and the empty ink error light goes out. The unit will charge the ink system while the light is flashing.
If the empty ink remains flashing or is on with the print head in the home position, then a cartridge may not be properly inserted. Press Stop and then push down on the cartridges. See http://support2.epson.net/manuals/english/spc/stylustx100tx101/guide/html/ink_4.htm for pictures and images.
If the ink isn't expended, use the Ink Replacement utility in the Epson software. For Windows, this is part of Printing Preferences in the Maintenance tab. Open the Devices and Printers (slightly different name in older versions of Windows) control panel. Then right click on the printer and choose Printing Preferences.
I hope this helps.
Dec 04, 2010 | Epson TX100 Series
HOW CAN I GET INTO THE ASK MODE ON MY CALCULATOR
  1. Press [2nd][WINDOW] to access the Table setup screen.
  2. Use down arrow to move focus to the line Indpnt: Auto Ask
  3. Use right arrow to highlight Ask and press [ENTER]
  4. Focus moves to line Depend: Auto Ask
  5. Use right arrow to higlight Ask and press [ENTER]
  6. Press [2nd][MODE] to (QUIT) the table configuration screen.
  7. You can now create your table.
Feb 07, 2010 | Texas Instruments TI-84 Plus Calculator
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
Epson sx 205, can't change the cartridge
With the power on and the lid up, click on the red stop (left panel). You will notice the cartridges move to the left and then they come back and stop halfway. Afterwards you should be able to slide the cartridges manually with your hand to the larger area on the right where you could do the cartridge change. Once you've moved it to that area just the lift the cover where the arrow is.
Jan 12, 2009 | Office Equipment & Supplies
Line shows up down right side of page that was copied or Faxed
your ink wel needs cleaning, do some deep cleaning and if that dont work take your ink well out and clean it manually
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
Nov 11, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Computers & Internet Logo
188 people viewed this question
Top Smart Technologies Computers & Internet Experts
David Payne
David Payne
Are you a Smart Technologies Computer and Internet Expert? Answer questions, earn points and help others
