Question about Kenwood KDC-MP235 CD Player
My kenwood is displaying protect across the screen and I can't get it to display different selections i.e tuner, USB, aux, media etc.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Try checking your speakers and speaker wires for shorts.. if that is not it you may have a bad output ic.
Posted on Aug 24, 2010
Kdc-mp
put a cd cleaner in your cd player see if that helps.
Feb 16, 2014 | Kenwood KDC-MP435U CD Player
I can not get the auxiliary to display on my deck, How do you get the auxiliary to display?
In standby mode press Menu botton at least one second, "MENU" is displayed, with the control knob push towards FM or AM and look for "AUX OFF" item, then push toward > to select "AUX ON1", to exit press Menu botton. After this procedure the auxiliary input should be available as a sound source.
Mar 08, 2011 | Kenwood KDC-MP2035 CD Player
When i turn on my indash dvd keenwood player it jus says standby and nothing works
Press the SRC button to turn unit on. The SRC button allows you to navigate between input sources,i.e. tuner, cd, aux, etc. Press and hold SRC button for second to turn unit off ( it will display standby).
Oct 08, 2010 | Kenwood KDC-MP205 CD Player
When ever i turn on my engine which means my kenwood kdc237 shud come on its just flashing protect protect protect no matter wot i press nothig happens need help cant do without music.
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Jan 20, 2010 | Kenwood KDC237SA CD Player
Owners Manual for Kenwood Car radio Model KDC-M4527
KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here http://kenwoodusa.com/Contact/ and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
I can't figure out how to get the player into mp3 mode. There is the button that changes between CD and tuner, but that doesn't do it.
Here's what they don't tell you: AUX isn't automatically an option when you scroll through the SRC button. You have to turn it on. I know, I know...stupid. I had to contact Kenwood (the maker of the unit) directly to get an answer.
  • First, press the SRC button repeatedly until it displays STANDBY.
  • Then hold down the Menu button until MENU is displayed.
  • Next press up or down on the right control knob, to scroll up or down, until AUX OFF is displayed.
  • Next hold the right control knob to the left or right until Aux switches on.
  • Now just press the Menu button to exit.
  • AUX will now be an option when you scroll through the SRC button
May 11, 2009 | Kenwood KDC-MP2035 CD Player
Only works in ''Tuner'' mode with ALARM on display
I called the dealer and he told me that the CD-Receiver is sensitive to voltage and it is possibly locked due to an unexpected rise during ignition. The unit has a reset button on the AUX (mini jack) port and after reset, it begun to work properly again. Only trouble now is I have to set my sound and tuner preferences again. No problem :-)
Apr 08, 2009 | Kenwood Car Audio & Video
Aux input. Kenwood ecelon dpx-701
You have to go into the menu and turn it back on. It is in the menu under "built in aux" and just switch it to on.
Feb 27, 2009 | Kenwood Excelon DPX-701
I can't use my ipod.. pressed SCR and only tuner and standby is displayed
Yes i had a very similar problem.
I have the MP-235. I could not edit my clock, my subwoofer settings werent active, and I could not switch to AUX.
If you have these problems, you have to hold down the menu button (bass boost) to enter the menu. then scroll around, turn AUX on, change the clock, etc etc.
You turn demo mode off the same way. Kinda silly how they have it all set up.
Hope that helps anyone in the future. i just wasted 3 hrs with this crap!
Dec 20, 2007 | Kenwood KDC-MP235 CD Player
Tuner error
Use a multimeter to check for connectivity to the sirius. Where did you mount the antenna? Maybe its a reception problem? Sounds like the head unit is going bad. Try shutting it down, and take the pace plate off, let it reboot and see if it works. Check to see if the Tuner is unplugged.
Nov 16, 2007 | Kenwood Sirius KDC-MP225 CD Player
Kenwood KDC-MP235 CD Player Logo
80 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
