Question about Cameras
I am loading a memory card to a canon 400D for the first time and have a Sandisk 2.0 memory card. Can't be sure which side is the label side. Hope you can help?
    Sergeant:
  • Cameras Expert
  • 488 Answers
When the lens is pointing down the lable is visable
Posted on May 09, 2008
Does Canon EOS Digital Rebel XTi 400D Black 10.1MP DSLR Camera work with Vista
You should not have any problems.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 22, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
Computer does not recognize my canon eos rebel xti 400D
You can download the driver aand reinstall it from this link: http://www.nodevice.com/driver/EOS_400D/get37008.html Make sure your existing Canon software, if any, is removed before installing the new driver. If this doesn't work you can always purchase a card reader and extract your photos directly from the memory card.
Sep 26, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
I have a Digital Rebel 40 D camera less than 1 year old and I removed the memory card and I cannot get it to go back into the slot. The eject button is still depressed after I depressed it to eject the...
im no expert, but i would use a flashlight to look inside the memory card holder and see if anythings messed up, and maybe jiggle the eject button a bit, and just maybe the button doesnt come up again until you push in the memory card. give it a little push they arent too terribly delicate. but make sure you are putting in the right direction. hope this helps
Sep 15, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I have an EOS Canon 400D digital SLR and my husband has bought me a Sony photo printer DDP-FP75 . I had wanted to be able to insert the memory card but it doesn't seem compatible. Can I print using the...
The two are not immediately compatible. The Canon EOS 400D uses a Compact Flash card. The Sony Photo Printer you have accepts SD and Memory Stick cards. Unfortunately, the CF card and SD card are very different.
The easiest solution I can think of would be for you to get an inexpensive card reader (make sure it accepts Compact Flash cards), attach it to your PC and then use it to read the CF card from your Canon EOS -- and print to your Sony printer.
I hope this helps. If it does, please rate the solution offered. My goal is always FixYa or Helpful, never TFT or IA. Regards,
Char1ieJ
Nov 24, 2008 | Canon Cameras
Delete data from camera memory cade
DO you want to delete all the data ... if yes then format it .... if No.. . then go to play mode and delete manually
Oct 17, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D not transferring photos to computer
Try installing or reinstalling the software on the CD ROM that came with the camera.
Jul 24, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error 2
Error 2 has to do with the Compact Flash (CF) memory card.
Try to copy the contents of the card with a card reader into your PC. Then try reformatting the card with your camera, not your PC.
If the card is empty or you don't mind about its contents, try to format the card right away with your camera.
If that does not work, then most probably your CF card is faulty. If it is still on warranty, send it back to the shop and get a new one.
Hope this helps.
Mar 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon 400D CF pin broken, power down
250 is a bargain if you value your time at anything over $10.00 per.
and canon will guarantee the results.
but...good luck
mark
Aug 20, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
