This is about an avalon astoria bay pellet stove insert. The auger fault light comes on and the auger stops. What is the fix for this? Can I do it my self? Is it mechanical or elect.
mrgreenz
  • 962 Answers
SOURCE: My pellet stove will start
You need to replace the auger motor. Go to fasco .com they may have one. Or enco.com I have a pellet stove and i have replaced both the auger motor and the motor that turns the hopper.
Posted on Nov 20, 2008
SOURCE: pellet stove auger motor
What's the matter with it? I can tell you how to overhaul and rebuild it.
Posted on Jan 13, 2009
protek480
  • 1714 Answers
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Posted on Jul 01, 2009
protek480
  • 1714 Answers
SOURCE: AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
protek480
  • 1714 Answers
SOURCE: auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Posted on Jul 08, 2009
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Auger is not getting power
The auger may be jammed. If you cant wiggle it then it probably is. If not then you have an issue with a sensor....ie an air leak, bad igniter, heat sensor.
Mar 02, 2014 | Pleasant Hearth Ghp Pellet Stove Large...
How do i fix ager on my pellet stove?
Hello Ethan, First I would uncouple and remove the auger motor from the auger shaft. Next turn the stove on to see if the auger motor turns. If it does turn, try to hold the motor shaft with your hand to determine if the motor has sufficient torque to turn the auger. If motor seems to be strong enough , use a pair of pliers or a vise grips and try to rotate the auger shaft. If the auger will not turn, it might be clogged up with pellets or pellet dust. The clog will have to be removed. If that is the case, I think the gears in the motor are stripped and a new motor is in order. Note: Damp pellets swell up and turn hard as concrete when they dry out.
Dec 06, 2013 | Home
Jamming auger onmagnum countrysidepelletstove
The softwood pellets are not the problem. The problem is the quality of those pellets. Make sure you are not using last years fuel and it has not been stored outside. Also check the auger system for junk, gouging and bending of the auger.
Nov 26, 2013 | MagnuM Countryside Pedestal Corn Stove
Pellet stove augur starts and will start burning and then it back up pellets will not come out the augur will not spit out the pellets and they just get chared
auger may be jamming or motor is starting to go unplug unit and open back and oil auger motor and check operation- auger may not be sitting right in feeder tube also try a different pellet some pellets are bigger(sizes vary from company to company) which sometimes jam at feeder in hopper
Nov 26, 2009 | Ruud UBHC Air Conditioner
Pelpro pellet stove will not start. Press the start button, igniter button lights up but nothing happens.
Is the auger light coming on to and dropping pellets into the burn pot? If the auger light is not coming on, you probably have an issue with the board controlling it. If the auger light is coming on, and pellets are dropping into the burn pot and it is still not lighting, then you have only a few other possible problems.
1. The air damper is not allowing enough air in, so pull the damper rod out 1/8" increments until it lights.
2. Your ignitor is faulty and not producing enough heat to light the stove. You can either contact a local dealer and get a replacement ignitor, or you can manually light the stove with a special firestarting gel made for pellete stoves. When you press the start button look into the burn pot. If the ignitor isn't bright orange, you aren't getting enough heat from it.
Hope this helps...good luck.
Oct 11, 2009 | Coleman Dryers
Auger on pellet stove doesn't turn
Jul 08, 2009 | Napoleon Auburn Pellet Stove Heater
My pellet stove will start but the auger will not drop pellets. What should I do.
Nov 20, 2008 | Kitchen Ranges
Heating & Cooling Logo
513 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
