Question about Philips 9FF2M4 9" Digital Picture Frame, Digital Photo Viewer
I unplugged my frame and now it will not come on
I deleted some photos from the thumb drive but they still show up on the digital frame?
you don't say which exact photo frame but here are some ideas that work on many. try powering off and unplugging, wait a minute or so, then plug back in and turn on. are they gone? if not, look for a reset button, pin hole and try resetting. good luck.
Mar 10, 2015 | Photography
Sony DPF-d72n digital photo frame will not switch on
Solved!
My Sony DPF-D72N frame is a few years old. Today I unplugged it (fool!) and plugged it back in. The screen would flash on and off to black. Power button light would turn on and off. After plugging and unplugging it a few times, it would not turn on at all.
I tested the power supply, and it showed 5V. I was about to throw the frame away, but on a whim, I tested a 2nd power supply. It worked!
So even though the power supply looked like it was working, it was only without a load on it.
Replace your power supply!
I happened to have a spare 5V 2A power supply, so I just chopped the end of the dead power supply and soldered it onto the new one.
And we all lived happily ever after.
Sep 07, 2013 | Photography
How do I replace an alternator for 2003 Pontiac Montana?
disconnect batt. take off belt, jack pass. side frame remove two frame mount bolts 18mm bolts (leave rt side wheel on) lower frame two bolts at the side of alter. one at front. unplug and disconnect wire. 20 mins.work
May 18, 2011 | Pontiac Montana Cars & Trucks
Kodak picture frame will not turn on, has no reset button, unplug and restart does not work. How do you open the frame?
I had this same issue. I hadn't used my frame in about a year and wanted to turn it on to show photos during the holiday gatherings. When i turned it on it would boot up then shut off. I realized the cord I was using wasn't the original cord and the output voltage was too low to power the frame. Make sure you are using the correct ac/dc cord.
Dec 19, 2010 | Kodak EasyShare EX1011 Digital Picture...
Housekeeper unplugged the frame, and now it turns on, but only with a blue screen that says 'system start'...nothing else happens
Connect the frame to your computer with the USB cable and to the AC outlet. Now turn it on. Under Computer or My Computer, look for a Pandigital (X:) drive.
If you see that drive, right click on it and select Format.
Choose FAT or FAT32 as the file system, check Quick Format, then Start.
Once it finishes, unhook the frame and restart it.
If you do not see that drive, your frame is toast. Grab your receipt and return to the store or call the company.
Jan 10, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
I'm trying to transfer pictures from my computer to the picture f
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  4. In the menu bar, select File ® Copy to.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Dec 16, 2008 | Kodak EasyShare EX1011 Digital Picture...
Have a kodak ex811 digital frame
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Once you connected your EX811 to your computer, and get the message “Use PC interface to copy files.” That means you can start copying files. Here are the steps:
Oct 27, 2008 | Coby DP-888 8-Inch Digital Photo Frame...
Philips 9FF2M4 9" Digital Picture Frame, Digital Photo Viewer Logo
52 people viewed this question
Top Philips Cameras Experts
Lyle Siemens
Lyle Siemens
Mohamed Ismail
Mohamed Ismail
Prashant Hattangadi
Level 1 Expert
Are you a Philips Camera Expert? Answer questions, earn points and help others
