Question about Bionaire Ulpa (UA0860U) Air Purifier
It is used ...how do I know if it is working....model LR 45976
    Top Expert:
  • 12,787 Answers
Couldnt tell you if used and as to operation your owners manual can tell you how to use it and set it up for peak performance
Posted on Sep 24, 2016
Model gch90703bxab
There could be other problems but check and see if your igniter is not burnt out. Ours did that and tried to ignite for two days and then I found I had to change the igniter.
Dec 05, 2017 | Goodman Manufacturing Goodman GMH950704CX...
It doesn't turn back on when I put the water catcher in it and I found this piece for it and I don't know where it goes.
I don't know the final solution but do want to brainstorm with you so you are not alone in the fixing process....
White Westinghouse Dehumidifier - Model Number >>> ????
http://www.searspartsdirect.com/partsdirect/brands-products/White-westinghouse-Parts/Dehumidifier-Parts
Sears is your friend here. They often have blow-up diagrams of how these units work. Just find your model number and look at the parts diagram if you can find it. 9/10 Sears has given me the answer through their online manuals.
Post your answer if you've figured it out.
Feb 10, 2013 | Air Purifiers
Everything works but the fan will not turn. I recently performed a thorough cleaning and installed a new ozone filter, but the fan will not turn. I tried turning the fan manually and the unit would run...
The fan needs oiling (except for the Fresh Air, which has sealed bearings and no removable front grid). I need to know which model you have to help you reach the fan shaft. However, if you're handy, you can figure it out. Remove the front grid (if there is one on your model) and pull off the fan blades. Use a light household oil (sewing machine, hair clipper, 3-in-1) to drip down the shaft as you turn it manually. This should take care of the problem.
If not, and if you need more extensive repairs or rebuilding, call Vollara (new name for EcoQuest) customer service at 1-800-989-2299 and use 16618 as your dealer referral number.
Jan 30, 2011 | Ecoquest Air Purifiers
I have 2 Ecoquest Fresh Air purifiers located in oposite ends of my basement. One in my work shop area (approx 28x32) and the other in my finished basement area (approx 28x50). The reason I chose this...
Hi Ed,
You should also clean the contacts points that touch the plates with the amonia and water solution. Use a brush and to remove any deposits on those contacts. Also the purification plates will not work if they are still damp when they are put into the machine. They must be completely dry in order to work. Use a hair dryer to dry off any water on the metal grid or allow them to dry for 24 hours. Hopefully that should get your plates going again.
In regards to when you should replace the plates. As long has the plate material is not cracked and you can clean the metal grids to a shine they should be good. But they should be able to last several years with good maintenance.
The RCI cells should be replaced every 3 years or when the machine displays "Replace RCI" message.
Hope this helps you.
Dec 04, 2010 | Ecoquest Fresh Air Air Purifier
How do I know if it is working?
WHERE CAN I DOWN-LOAD THE OWNERS MANUAL FOR Sharper Image/Ionic Breeze/s1830
Jun 22, 2010 | Sharper Image Ionic Breeze GP SI730 Air...
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
Ionic breeze gp just stopped working
Hi.
I don't know if you are still trying to repair the air purifier.
About your Ionic breeze purifier, I wanted to report that they are not being manufactured anymore because of heath concerns. New model built from 2008 use a completely different technology. Parts are also not distributed anymore, and the new Sharper Image does not provide any support for the old model.
I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Sep 28, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Home Depot Switch Doesn't Work. Does anyone know where to get a
Google search Hunter Fan Parts. Should find what you need, and have it in a few days.
Regards, --WoobieDog--
Jul 10, 2009 | Hunter 30216 3-SPEED FLOOR MODEL Air...
How do you know if it is working (fresh air) Ecoquest?
I don't know if I'm allowed to post a link or not, but I'm giving it a try.
Here is a link to the .pdf for the product manual for an Ecoquest FreshAir unit:
http://www.ecoquestintl.com/dlrdown/website_om/faom_62-00230.pdf
This is the one that has the 'away' mode on it.
Here's the main website where the product manual link can be found, it may help you find your other manual:
http://www.ecoquestonline.net/retail_products/fresh_air.asp
Hope this helps!
susanszy
Nov 10, 2008 | Ecoquest Fresh Air Living Air Purifier
Where can I have a Ionic Breeze Quadra Model S1637 repaired?
Try this link, pair for $10- http://breezerepair.com/parts.html
Jul 16, 2008 | Sharper Image Ionic Breeze® Quadra® 4.0...
Air Purifiers Logo
221 people viewed this question
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
