Question about HP OfficeJet 9120 All-In-One InkJet Printer
HP Officejet 9120 all in one
Printhead latch open?? Error
I want free download hp officejet 9120 printer drivers what a i do??
Posted on Dec 04, 2008
How to clean printhead
Hi Melissa,
Remove the cartridges
You will find a lever ( latch on right side )
Lift the latch and remove the Printhead.
Clean the contacts at back of the Printer ( electrical dots ) with lint free cloth.
Install the Printhead, lower the lever/latch and install the Cartridges
Regards,
Sean
Feb 14, 2013 | HP Officejet 6000 All-In-One InkJet...
Hp color Inkjet printer cp1700 - error: printhead access latch open.
There should be a small switch that depresses when the access latch is closed. Check the part that the latch presses on, it should move freely and be springy. Sometimes these actuators will pop out of place or completely off of the switch.
Jan 28, 2013 | Office Equipment & Supplies
How to change the toner
This unit does not use toner. It uses ink cartridges, hence it is called an OfficeJET All-in-One INKJET Printer. To change the ink cartridges, you lift the latch located on the front of the unit above where the paper comes out.
Aug 26, 2010 | HP OfficeJet 9120 All-In-One InkJet...
OfficeJet 9120 All-In-One InkJet Printer: hello The fax in my hp officejet 9120 is not w...
According to the manual found at support.hp.com, you need to go into the setup menu for faxing and enter the necessary information prior to faxing.
May 16, 2010 | HP OfficeJet 9120 All-In-One InkJet...
How can i open the hp officejet 9120 in order to replace the toner?
Get the manual from this site and read th einstructions about setting up.
http://www.retrevo.com/support/HP-9120-Multifunction-Printers-manual/id/260ag504/t/2/
Hope this will work for you
Have a good day
luciana44
Dec 03, 2009 | HP OfficeJet 9120 All-In-One InkJet...
Unable to print on HP officejet 9120. Error ; Load A4 in tray 2, Plain paper. Tray is empty or media type/ size in tray is incorrect. Ensure media in tray matches printer driver or control panel setting.
when you give print command go to print properties and choose the paper size as well as the tray to print aslo in printer set the the size or paper in tray.
Nov 20, 2009 | HP OfficeJet 9120 All-In-One InkJet...
New 6500 OfficeJet installation issues -doesn't recognize printhead
you will need to contact HP for replacement parts here is there technical support # 800-474-6836 they are open 24-7
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
The printhead latch is open
It is the mechanism that holds the ink cartridges in place.
Sep 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
Looking for Hp 9120 driver for Mac OsX.4 thanks!
Here the driver download page: HP Officejet 9120 All-in-One Printer.
Do not forget to rate the solution.
Many thanks.
Mar 01, 2009 | HP OfficeJet 9120 All-In-One InkJet...
IDS failure, call HP message comes up
Hope this helps you. This error is caused by either a correct or incorrect detection of air in the manifold. The steps below will clear the error condition, which should solve the problem if it is caused by an incorrect detection of air. If there really is air in the manifold, however, this procedure will not solve the problem and the printer will have to be serviced. Step 1 - Remove all printheads CAUTION: Do not touch the printhead tower. Do not remove the printhead handle. Keep printheads out of the reach of children. Figure 1: HP 14 printhead c00042423.jpg 1 - Handle 2 - Tower
  1. Make sure the unit is plugged in and the power is turned on.
  2. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  3. Wait two or three seconds, then unplug the power cord.
  4. Open the printhead latch. See the illustration below. Figure 2: Open the printhead latch c00042424.jpg
  5. Remove each problem printhead by lifting the printhead handle and pulling up. See the illustration below. Figure 3: Remove the printhead c00042425.jpg
Step 2 - Reset the internal error state NOTE: This step must be performed before the printheads are re-installed.
  1. Close the printhead chute.
  2. Close the access door.
  3. Plug the power cord back in.
  4. Turn on the power. The front panel should read No Printhead. Will damage Product. Insert [color name] [icon] printhead now . NOTE: The carriage may make a grinding noise when you turn the power on. This noise is normal.
  5. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  6. Wait two or three seconds, then unplug the power cord.
  7. Open the printhead latch.
Before re-inserting the printheads, make sure all the electrical contacts have had at least five minutes to dry. Step 3 - Insert the printheads
  1. Place each printhead in its slot in the printhead carriage. The colored shape on the top of the printhead should match the colored shape on the proper slot on the printhead carriage.
  2. Press down firmly and evenly on both the front and back of the printhead, as shown in the illustration below. Proper seating is essential to making good electrical contact.
Figure 4: Seat the printhead c00042431.jpg Step 4 - Close and check the printer
  1. Close the printhead carriage latch and make sure the loops catch the hooks. See the illustration below. Figure 5: Loops catch hooks c00042432.jpg
  2. Snap the latch into place.
  3. Plug in the power cord.
  4. Close the print carriage access door.
  5. Turn on the power.
  6. If the error clears, a message to align the printheads may appear on the HP Officejet D and HP Officejet 7100. Press Enter to align. If the error persists contact HP. Printhead replacement will not resolve this problem - the printer will have to be serviced.
Jan 08, 2009 | HP OfficeJet D135 All-In-One InkJet...
HP OfficeJet 9120 All-In-One InkJet Printer Logo
186 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
