Question about Whirlpool ED0GTQXMQ Side by Side Refrigerator
Ice maker not making ice - Whirlpool ED0GTQXMQ Side by Side Refrigerator
    Problem Solver:
  • 6 Answers
If you have a whirlpool icemaker inside of your freezer there is a white cover over the ice maker (it's square). Remove the square cover with your hands or stick a flat head screwdriver in the side until you can pull it off.
Once the white square cover is removed, you should see a white wheel with gear teeth. In the middle of the white wheel is a plastic snap that should be holding it in. I noticed that one of the little plastic snaps was broken...which caused my "no ice" problem.
A simple test is to push the white wheel toward the icemaker. If the wheel starts turning, you have found the problem. You see, behind the whhite wheel are metal contacts that need pressure for the ice maker to work. Without the center plastic snaps holding it it, the pressure is gone...and so is the metal to metal contact.
I previously called Whirlpool, searched all of the web...to no avail. Every other solution was "check for ice blocking the water tube" or "replace your water filter". That's all balony. If your regular water dispenser is working, you don't have an ice problem. And if your water dispenser is working, you don't have to change your fitler either.
If you realize that the little white wheel is the culprit, just google "whirlpool module" and you will see it for sale. Look at the pictures and make sure it looks like the one you have. The model/part numbers may be off, but that's okay. I found one on ebay for under thirty buckaroos with free shipping.
Hope this helps.
Posted on Mar 28, 2009
    Genius:
  • 1,198 Answers
How old is the unit? These things are actually very delicate, a power surge will take them out. The devil to service them is that they are difficult to diagnose out of the freezer. If you see a burnt or melted spot on the timer wheel, it's done. The timer wheel is behind the square plastic cover, which pulls off the front. That front part, which I think is called the module, is replaceable. On the two units I have worked on, that was where the problem was.
Posted on Jan 24, 2009
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Smeg FA561X ice maker not making any ice. Water dispenser is fine and rest of fridge/freezer fine, just no ice in the ice storage part
ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- In most of the cases the fault is water valve at the back of ice maker section, on some refrigerators the valve is at the lower section. ------------- The above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
Jun 29, 2011 | Smeg FA561X Side by Side Refrigerator
My icemaker is not making ice. The water dispenser is working. Settings are fine, no ice at all in ice compartment. Filter light is not on. Ice maker button is in on position
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- In most of the cases the fault is water valve at the back of ice maker section, on some refrigerators the valve is at the lower section. ------------- The above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
This will help. Thanks. Helpmech.
May 16, 2011 | Kenmore Refrigerators
Is ice maker not working, do you mean it has no power at all.Then its faulty control board.But if there is power to ice maker and its not making ice then its not board but it can be faulty valve.---------
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
May 12, 2011 | Whirlpool Refrigerators
Fridge will dispense water and ice but will not make ice
You question " Fridge will dispense water and ice but will not make ice" If its not making ice then how its dispensing the ice. This is bit confusing me,-------- as per your question i assume you mean to say, that its dispensing the watyer but its not making ice. ------------
Apr 26, 2011 | Refrigerators
Ice maker stopped making ice. Water line is hooked up and working. Just won't eject ice
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------But if ice is getting made in the ice tray,but the ice is not ejecting out then there is blockage to the ice ejecting blade.May be some ice is got stuck below inside.Clear all ice frost collected under the ice chamber.And then see.---------------
Feb 21, 2011 | GE Refrigerators
The ice maker doesn't make ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 07, 2010 | Viking DTBB363 Bottom Freezer Refrigerator
GE ice maker, solid ice in ice maker
Many ice makers have an adjustment screw behind the front cover that shows plus or minus. Try the minus turn of the screw that should shorten the amount of time the ice maker fills. If electronic please call the company you purchased it from and explain the problem. Sea Breeze
Jul 23, 2009 | GE Refrigerators
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
Whirlpool ED0GTQXMQ Side by Side Refrigerator Logo
215 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
