Question about Krups XP4030 Espresso Machine
My espresso has grounds in it. It looks like sludge.
  • rsmcginty Aug 24, 2010
    How fine of a grind do you suggest?
  • rsmcginty Aug 25, 2010
    after cleaning espresso maker with 2 cups of vinegar, my espresso still has sludge in it. I have a burr grinder and I have it set on about 4.
  • 11,896 Answers
If you have the slimy ground in your coffee, I would recommmend getting a different type of filter. If you have the screen type of filter that is washable and re-usable, this will happen alot.
Posted on Aug 25, 2010
  • 10,865 Answers
Hello. It is time to give your machine a thorough cleaning. Run 2 cups of vinegar through the machine and also clean the filter. Finally, consider the kind and grind of coffee you are using. If it is not designed for making expresso, that alone may be the problem. J.
Posted on Aug 24, 2010
    Top Expert:
  • Krups Master
  • 76,118 Answers
Are u following the instructions outlined in the owner manual to make expresso, are u using the correct grind
  • yadayada
    yadayada Aug 26, 2010
    use a paper filter disk
Bosch benvenuto b30 had for years and loved. Now when use beans the coffee/espresso is too watery and pucks are like sludge after. Works good when use preground coffee .
You have accidentally turned down the brew strength selector, on front of unit just above "clean" and "descale" buttons. Dial it the the maximum. Will grind longer, make more grounds, larger puck, stronger coffee. Or this dial is broken/ wire broken etc. u can disassemble per some other posts on here and check wire connections. I did all that then realized someone had just turned it down. So I turned it to maximum strength and problem fixed.
Oct 15, 2013 | Bosch Benvenuto B30 Espresso/Coffee Maker
Capresso jura S9 IMPRESA
hi did you ever fix this problem, i too have this - i know it is because of coffee sludge built up in the system but i want to know how to open the machine and give it a good clean - cant seem to work out how to do it though.
Apr 30, 2010 | Jura Capresso Impressa F9 Espresso Machine
Coffee grounds in bottom of commercail size coffee maker
If you will call 800-286-6070 we can help you with this.
Nov 01, 2009 | Bunn 10 Cup Home Coffee Brewer
Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Jul 02, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Coffee crounds
The problem you are having is common when these units have been in use for a while. There is a sludge buildup preventing the brewed coffee from leaving the brewer soon enough. Straighten out a paper clip and use the wire to open up the blockage in the hole where the coffee would enter the coffee cup. You may have to go up from the bottom in order to do this thoroughly.
Feb 12, 2009 | Lavazza Espresso Point Capsule Machine
The perfect cup!
When I brew coffee, I use a mild to medium columbian roast. I then use one tablespoon of coffee grounds for ea 2 cups of water as marked on the pot. The measure of coffee is the same whether you use the ground or the whole bean.
I always use fresh filtered water. Chlorine, flouride, and any other ingredient in the water affects the flavor of the coffee.
I stay away from the french roasts & dark roasts. they are very bitter and frequently taste like ashtray to me.
I assume that the coffee pot uses a 6 oz measure of water for their one cup of coffee.
I frequently check the drip area for coffee sludge buildup. That also affects the coffee flavor if the coffee sits at all.
Hope this helps
Jan 13, 2009 | West Bend 55108 Espresso/coffee Maker
Saeco Easy hums instead of packs grounds
I think the brewing gears has to be replaced.
Aug 26, 2008 | Saeco Easy Espresso Machine
Bypass doser malfunctions
Happens when the preground coffee is not ground fine enough, you may have to put the pre ground coffee in a manual coffee grinder to make it finer. The machine is not really designed to brew regular coffee grounds.
Jan 20, 2008 | Saeco Magic De Luxe Espresso Machine
Krups XP4030 Espresso Machine Logo
62 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
