Question about Dryers
I have an ASKO dryer model 7005 and have the same problem as your recent email customer with ther eemail problem below: The dryer will start but will not stay on once I let go of the s button and if i hold the button it works but does not get warm. I am having this same problem as the person who you wrote this problem above on July 10. I read your solution and the dryer vent is blowing just fine. The dryer still works for several loads and then trips the reset again. Does that mean that the heater element is shorted or bad like you say? If shorted wouldn't the heater not work at all and just trip the reset right away? If not, is there any way I can troubleshoot to the next level to make sure that heater element is bad before I go out and buy a new heater element only to find that it is something else. Is there somewhere I can check a voltage or resistance to see if it is shorted or working properly. I am an electrical engineer and know how to read schemetics and use a voltmeter and other electrical equipment? Could it be a faulty reset switch. Please help Mike
  • mikek01 Aug 24, 2010
    Also, the air coming out of the vent when it is running is forcefull and warm as would be expected. It runs about 6 or 12 loads just fine before the reset trips. If the thermostat is bad which one would it be there are several.
    Yes the rest trips and I pull the dryer out and reset it. It runs about 6 or 12 loads just fine before the reset trips again. If the thermostat is bad which one would it be, there are several . Also, the air coming out of the vent when it is running is forcefull and warm as would be expected. The air comes out strong enough to lift open the outside flapper all the way and is warm air.
    I also pulled out the filter and washed it with warm water and soap. Could there be lint buildup somewhere else in the dryer or somewhere in the venting chain. It is about 10 years old, ASKO model 7005?
  • Dryers Master
  • 2,605 Answers
Hello Mike,
Welcome to Fixya,
Let`s start with the obvius...have you checked the manual reset hi-limit cut-out at the back of the dryer you spoke of ? It`s located on the back panel about 1/2 to 3/4 the way down and will look like a small round black rubber button.
Push it to see if it "clicks" and then try your dryer.
What to look for if it`s tripped...
  1. Plugged venting - make sure your venting is clean and clear of lint or un-obstructed where it exhaust`s outdoors.
  2. Plugged lint screen - ( part # 8061812 ) This is especially relevant if one uses fabric/static sheets as they contain wax...especially lesser name brand sheets. You can clean the lint screen by removing it from the door and with some mild soap and hot/warm water wash it...an old toothbrush works well for cleaning it. Careful not to rip the fine screen.
  3. The blower wheel/fan impeller ( part # 8055200 ) attached to the front of the motor which moves the air through and over the clothes in the drum may be loose, broken or covered in lint, hence causing the hi-limit to trip.
  4. A faulty heating element ( part # 8063808 ) can also cause the hi-limit to trip as well. If the element is shorted to the casing it will not cycle "off" via the 115°C (part # 8008807 ) cycling thermostat, thus cycling off via the hi-limit 150°C ( part # 8008487 ) as you stated.
  5. Let me know how that works or if you`ve already tried that. If it is tripped, resetting it may only temporarily resolve your problem since it is usually tripped due to venting or heater issues. If it is not tripped let me know and we can explore other possibilities.
Note
The resistance value to look for on heater - 66.7/25.7 ω The element has a maximum power rating of 2620W but consists of two loops of 1900W and 720W, which permits rewiring from 2620W to
1900W.
Good luck.
Macmarkus
Posted on Aug 24, 2010
  • Mark MacDonald
    Mark MacDonald Aug 24, 2010
    Hello again,
    Based on what you`vevalready said and done, I`d suggest removing the back heater cover and seeing if it is completely clogged with lint.
    You`ve mentioned there is good air flow, lint screen cleaned, it has to be something to do with the heater. Like I said, it being clogged with lint which will contain alot of moisture after cool down, hence it can potentially trip the hi-limit periodically.
    The back is easily removed, ( just the inner panel portion, kind semi-oval/egg shaped...not the outer cabinet/back panel perimeter screws ) just be careful once you`ve got all the screws out the edges are sharp.
    When you un-fasten the heater assembly, it will typically have plastic "zip ties" holding the wire harness to the panel, I usually cut it and replace the zip tie later.
    Let me know how you make out, you`re on the right track though.
    Good luck.
    macmarkus :)
My asko dryer 7005 works the heating element but the drum d,not turn
broken belt , defective timer, defective board if electronic, defective push button start switch, defective cintrifugal switch in the motor itsself, defective motor, foreign object blocking fan motor in housing, stuck drum rollers.
Mar 02, 2012 | Asko Dryers
Asko 7005 dryer, start capcitor is cracked and has hard goo coming out the side, dryer wouldn't start and stay running, now it won't start at all. Could the capacitor be the problem or do you think...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 17, 2011 | Asko T781 Electric Dryer
Asko dryer has no power.Washer ok
By-passed fuses,dealer said he's done hundreds.Saved me a service call.This is the 1st and only problem we've had in 10 years! We love our Asco.
Feb 16, 2010 | Asko Dryers
Asko dryer model#7005 when i start the dryer i push the start button and let it go it does not stay on. If i hold the start button down the dryer will stay running.
Hi There, Sounds like there is a relay switch that may be faulty, the power should latch on when you press the start button, I am unsure of this model type, but usually there is a small PCB inside the unit behind the facia, remove the top to expose it, and you can either replace the PCB or replace the relay the latter being cheaper but more work as you will have to reflow and solder the relay
Nov 27, 2009 | Asko Dryers
Asko dryer 7005 will not start. When I touched
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Nov 22, 2009 | Dryers
No manual, don't know what the buttons do
laundry.manualsonline.com/.../asko/asko_clothes_dryer_product_list.html
Mar 31, 2009 | Asko T731 Electric Dryer
Asko 7005
Go reset your circuit breaker. Even if it didn't pop out, reset it.
Oct 25, 2008 | Dryers
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Dryers Logo
46 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
