Question about AOC 919Swa1 - Black 19 inch LCD Monitor
My widescreen TFT185W80PS AOC monitor shows the normal screen image/windows, but stretched wide and there is no resolution option except 1280X1024 in i-Menu(my operating system is window XP sp3)
5 Suggested Answers
  • 63 Answers
SOURCE: AOC 16
Some where on you screen is a menu button that allows you to access teh screens utilities. One of teh utilities is the screen's geometry. Iti is here that you can adjust the length, width, position, etc.
You may want to access the vendors web site and sownload the user manual.
Posted on Oct 06, 2009
SOURCE: Hannspree 19" Widescreen resolution available
I have the same problem. i downloaded a generic driver that allows 1600 X 900 resolution. this is better..things are taller rather than wider (with the 1280X1024 resolution). i dont understand why there isnt a 1440X900 driver available for XP systems.
Posted on Jul 31, 2008
driveallnigh
  • 89 Answers
SOURCE: HP W2007 can't adjust resolution screen stretched
What operating system are you using?
Posted on Feb 26, 2009
SOURCE: i have aoc v22+ led monitor. Its max. resolution
my aoc v22 led monitor osd function has been locked. how to unlock it?
Posted on Sep 01, 2010
Tip
How to change the desktop background image.
There are two ways in which to set your desired image to your desktop background.
Option 1
1) Fistly locate the picture you want as your desktop background.
2) Then double click the image to take you into Windows Picture and Fax Viewer as the default picture viewer. Once there right click anywhere on the picture and click Set as Desktop Background from the pop up menu.
And there you have it. The image is now your new desktop background.
Option 2
1) Fistly locate the picture you want as your desktop background.slasher_x.gif
Then right click on the image and select Set as Desktop Background
Option 2 is a slightly quicker way of doing it as you don't really need to view the entire image in Windows Picture and Fax Viewer as long as you can see the thumbnail of it or you are in Filmstrip view.
To enable the thumbnail or filmstrip file view
In the picture folder click on the menu view and then click on the option Thumbnails or Filmstrip from the drop down menu. Or you can find the view icon on your tab menu.
NOTE: Just remember that if your image is in a 4:3 aspect ratio, such as 800x600, 1024x768, 1280x1024, it will be distorted and stretched if you are using as a background on a widescreen monitor.
Older 4:3 monitors (square monitors) use sqarish image resolutions such as 800x600, 1024x768 and 1280x1024.
Newer widescreen monitors use widescreen image resolutions such as 1152x864, 1600x900, 1680x1050 and 1920x1080.
on Nov 10, 2010 | Computers & Internet
Image set up of screen is only half of the monitor
If you v-size is already at 100% then the issue is with the picture being sent to the monitor. Based upon what kind of input you have for the monitor there is a number of different ways to fix this. I will assume you are using the monitor with a desktop computer. If this is for XP, then there is a simple fix as follows, adjusting your display properties:
Right-click on your desktop background and then click on "Properties" this will open up a new window. Select the "Settings" tab, then drag the green arrow in the "Screen Resolution" field to the desired setting. Since you have a "widescreen set-up" you more than likely have a resolution where the first number is about twice the second number...they should be close to even to have a square image (bigger numbers show more detail than smaller numbers).
Hope this helps!
Jul 16, 2010 | AOC 7F 17" CRT Monitor
How to change the picture format on my monitor?
You should set your PC to the monitor native resolution for this monitor: 1440 x 900 @60Hz.
Here is the spec for your monitor: http://www.dealtime.com/xPO-AOC-919Swa1-Black
Jan 27, 2010 | AOC 919Swa1 - Black 19 inch LCD Monitor
I cant fit the whole image on the screen. The options to adjust only allow me to adjust the width...it wont let me show both the top of my windows open AND the start button.
Your resolution may be set to high on the computer. Or you have a standard screen resolution set and since the monitor is a wide screen, it is cutting it off.
Try a different resolution 1440x900 is what the va1930wm uses.
If using a laptop with a standard type screen on it, you may have to set the laptop to just light the monitor to allow this setting to take.
Since this monitor is a wide screen, it may have options in the menu to stretch or zoom on an image if the resolution is not set to a wide screen format.
Dec 03, 2009 | ViewSonic VA1930WM LCD Monitor
The pictures are too wide all people look fat
You most likely have a wide screen and the screen resolution needs to be adjusted to suit the monitor.
Go to the Control Panel - Display and adjust the screen resolution until you get a normal image and correct screen aspect screen ratio. Start with a screen resolution of 1024X768 and gradually increase it until you get an image that suits your screen.
Oct 01, 2009 | Acer Computers & Internet
AOC 917sw 19 inch monitor resolution issue (same as above)
Have you try the following resolution values:
1280 x 768
Usually its the standard for widescreen view
Please don't forget to rate if answer is useful
Jun 18, 2009 | AOC 917Sw 19" LCD Monitor
Acer P193W monitor stretched image
What service pack of windows xp are you running? Also, do you have your old monitor, if so, then plug it in and see if the same problem occurs. If not , go under the settings for your graphics card (not windows display options) and see if there can be a correction made to the settings for your monitor. Also, try going to microsoft.com and updating your computer (it's free) and you'll probably get the required driver to fix the problem from them. Check under your control panel and see if you have automatic updates turned on, if so you may want to limit what updates are to be installed by allowing updates but you choose which one's to install. Hope I could help. My e-mail
tallcoolone@yahoo.com .
Jan 04, 2009 | Acer X193W LCD Monitor
How do I get the widescreen monitor to show unstretched images?
i had the same problem with my new widescreen monitor... turns out the best setting (at least, for my specific monitor) was 1440 by 900 pixels. at this setting the desktop still stretches itself to fill the entire screen, but everything else is completely unstretched. (to adjust the screen resolution, right click anywhere on the desktop, then go to properties, then settings.)
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
AOC 919Swa1 - Black 19 inch LCD Monitor Logo
1,712 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
