Question about Saeco Vienna De Luxe Espresso Machine
The little drawer on the side that the puck drops down into will not go back in. Its like the level inside is stick down so the drawer cannot go completely in. Help me please asap ,
  • 1,089 Answers
Hi
Here is one way to get it back in.
Look on the left side where the box goes in. On the bottom left side of the opening inside the machine is a round part of the body with a long slot in it. Turn the machine on and slide plastic knife in front of the slot, then push towards the back of the machine. This will start the motor and cycle the brew unit back to where it needs to be. Then you can slide the box back in.
Remember, when the brew unit is moving, don't remove the dredge box or it will stop the machine and you will have this problem again. Let it stop before you remove anything.
Posted on Aug 24, 2010
Remove stainless front
Pull the drawer out a little bit and look on the sides just behind the front panel. You'll see a little round plastic piece (about 1/2 or 5/8" diameter) with a plastic rib going through the center. That is the head of a plastic pin that holds the panel in place. Get a long-nosed pliers, grab that rib, and pull the pin straight out. Do the other side. Now pull the front panel down and tilt out the bottom a little. Don't let it drop, there is a ground wire that you have to detach before you can put that panel some place else. Putting the panel back on is more difficult, because the door wants to close as you're trying tp push that panel up and back in place. Stick something in the top of the drawer so it won't close. Sometimes it helps to push the glides on the bottom of the drawer back about and inch or two. You have to look underneath to see how to release the catch for the drawer glides.
Sep 28, 2014 | Fisher and Paykel Dishwashers
Saeco Royal Digital Plus - I cannot insert the brew unit into the machine
Hi Remove the dredge drawer. Open the right side door. On the left side and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door, insert the dredge drawer and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door, pull out the dredge drawer and insert the brew group. Done PS: If it still won't go in you might have a broken brew drive. The gear in the back of the machine where the brew unit goes has 2 large teeth. They should be in the 10:00 and 12:00 position. If they are in the 3:00 and 5:00 or that side you have a broken drive and the gears need to be replaced.
Jul 06, 2011 | Saeco Royal Digital Plus Coffee...
Error message: 'brewunit is blocked' and i cannot get the brewunit out of the machine to look at it. it is stuck pretty hard. dont want to break it...any suggestions?
Hi
Your showing a Syncrony but this is for a Syncrony Compact. They are different.
Open the door. Remove the drip tray, dredge drawer. On the left side and towards the back of the brew group, there is a single screw in the brew group. If you can't get the dredge drawer out, just move it as far to the left as you can to get to the screw. Remove the screw. Grab the handle, squeeze and pull carefully, but firmly fast. Everything will come out (drip tray, dredge drawer, brew group and there might be water in the drip tray). The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and then to the center of the brew group. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group into the machine. First you must insert the dredge drawer back into the machine. Close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, pull out the dredge drawer, drip tray, then open the door and insert the brew group. Slide the drip tray,dredge drawer back in, close the door and test.
May 14, 2011 | Gaggia Syncrony Compact Digital Espresso...
Refridge is warm, freezer is working fine. There is a damper controlled by a small motor behind the meat drawer or top drawer. Pulled out drawer, and hole that gets air from freezer was blocked with a...
This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace.
This is the cold zone fan which supplies cold air to the meat and crisper drawers.
Feb 07, 2011 | Maytag MSD2758GEW
I have a stove and it is frigidaire and it the bottom drawer back clips fell out and it just drops when I close it how do I put the clips back in
Just happened to us and my wife figured it out. They go on the bottom of the side panels of the drawer at the back. The hook part sticks inside the drawer.
Dec 29, 2010 | Frigidaire FEF336BC Electric Kitchen Range
I removed the black brewing system from inside the coffee machine, in order to clean it. Now I can't put it back in. The little wheel attached to the back wall of the coffee machine doesn't want to fit...
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now replace the tray and insert the brew group. If it still won't go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Oct 23, 2010 | Saeco Spidem Villa
I can't the insides of the machine back in, it was opened when the machine was running the dial doesn't match up
Hi
These instructions should help.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Oct 30, 2009 | Saeco Incanto Classic Espresso Machine
My Canon 5050 bottom drawer came out, an arm inside has popped up and we now can't close the drawer. We've can't gently put the arm back down. How can we get the arm down again?
Prior to the issue you facing basically ,you check whether u can reattach the arm or you can try to compare with another drawer to figure it out .See anything that broken or crack pieces.Kindly post pic to me ,I'll might help u.Thanks ,pls rate me!!!!
Sep 20, 2009 | Canon Office Equipment & Supplies
I keep getting a message that says dreg drawer missing what is this? is this where the cup sits when it is getting filled? coz i have taken it out and put it back hundreds of times
The dreg draw is the little draw where the coffee pucks are released to after they've been use.
Typically if this message stays on even though the draw is in place indicates a bad microswitch.
doesn't cost much to get fixed, but i would take it in to a service center as it is a little rough to get to.
Jul 06, 2009 | Saeco Magic Comfort Plus Espresso Machine
Ice maker only crushes/does not cube
Remove the ice bin. Look at the back wall, behind where the bin was. You should see a rectangular hole, about 1.5 x 1 inches near the bottom of where the ice bin was. There should be a white plastic part inside the hole. This plastic part should be able to be lifted up with your finger, and drop down again when you release it. If is does not move, it may be frozen, or the electrical solenoid connected to it may have melted. If the part moves freely, just replace the ice bucket and try to dispense cubes again. (the metal arm sticking out the back of the ice bucket might have gotten on the wrong side of the white plastic part in back)
May 21, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Saeco Vienna De Luxe Espresso Machine Logo
23 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
