My dell desktop was working fine but now when i turn it on the harddrive lights up but the screen says no signal then the screen turns off. ive hooked up to my t.v. it says the same thing no signal so its not the moniter at fault
  • Red Gatdula
    Red Gatdula Aug 24, 2010
    HI,
    Do you hear a beeping sound when you open the computer? .
    usually that indicates where the main problem is.
    You can try reseating the memory on it.
    Check the cables inside it might be loose.
    also check you video card.
    Cheers!!
    Sergeant:
    Champion:
  • 389 Answers
If you are useing a video card,try pulling it out and reseating it.if you are useing on board video try clearing the bios per your instruction manual then re do the settings of the bios(ie:date,time,boot priority etc.)and see if the monitor comes back on.or while in the bios u can just set it all to default settings.also try to reseat the memory.
Posted on Sep 03, 2010
I have a Dell 530s Desktop. When I turned it on I get a Dell splash screen then it goes black. I can not even get anything to work thru the USB outlet. What could cause this
Have you check the BIOS if the harddrive is detected? You may want to use a working harddrive and check if harddrive cable is not loose or you can try to boot to a bootable disc just to isolate the issue.
Hope this helps.
May 20, 2011 | Dell Inspiron 530s Desktop Computer
System unit led is yellow and start good condiotion but no signal
The light on the LCD screen stays yellow?
I would start with puling out the ram chips and see if it works,
If you get some beeps and video works with ram chips out, then its a bad ram chip.
If thats not it.. unplug all cards cd/dvd rom and harddrive to test motherboard and CPU chip. see if you can get video to work with everthing but cpu and power suppy unpuged
Apr 28, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
My Dell Dimension 4600 will not turn on. Steady Amber Light
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Sep 03, 2009 | Dell Dimension 4600 PC Desktop
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
Dimension e521 black screen no video signal
if your num lock key responds, you may have to reseat/change the video card (if you are sure monitor is good). else you need to replace your motherboard.
Getback if you need any clarifications
Jan 09, 2009 | Dell Dimension E521 PC Desktop
When i turn on my computer it works perfectly fine apart from the srcreen is not picking up my signal ive tried the screen on another pc it works fine and im not sure what ive got to do.
Try disconnecting power......reseat the video card, unless it is onboard. If it is on board video then the mother board is garbage. You can insert a 3rd party video card and try that and see how it works.
Dec 04, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
