Question about Samsung SyncMaster 753S 17" CRT Monitor
Problem with Samsung 17" Syncmaster 793 MG monitor
No image at the screen but white light appears if i switch on the monitor (no CPU connected), and green led normally on. Help plz!!!
  • OKCoiii May 05, 2008
    the image looks like appear but very very blurred and dark,also with bad shape!!!!
  • boybawang Aug 19, 2008
    I have Samsung Syncmaster 793mg. here's the problem.
    1. When I turn-on the system the Monitor screen is blank but the green led blinking. I can't see anything. not even the bios start-up texts.
    2.I tried unplugging it's cable connecting to the video-card and a video-outlet-image with "?" appears in the screen. It's an indication that the display is OK according to the monitor manual.
    3. Even the screen is blank, the computer continues to boot. Infact I can hear the windows welcome sound.
    Please help!!! and thanx in advance
As you said the monitor is OK. the RAM in your system is not working so you are not able to see anything when you turn on the monitor. Replace or reconnect the RAM and check it once again.
Posted on Jan 02, 2012
I have managed to solve the problem already :) It's because I wrongly connected wire to the built-in graphics card
Posted on Oct 02, 2008
    Problem Solver:
  • 18 Answers
You might be having problems with the cable connection from the monitor to the video card. Check the cable for open wire.
I have a Samsung SyncMaster 172n monitor and the screen stays black when I turn the power on. The power light starts flashing about 3 seconds after I turn it on. All the power cords are plugged in, the...
When the monitor starts up you should be able to see the Samsung screen logo, if not it does point to the monitor. But lets be sure! hook a spare monitor to the computer, if it is okay! the Samsung Monitor is the problem and is not cost effective to repair, cheaper to replace. Now if both screens show the same problem, this indicates the Video Graphics Card in the computer is the culprit.
Jan 19, 2011 | Samsung SyncMaster 172N 17" LCD Monitor
My screen does not come on when computer is turned on.I have a samsung syncmaster 2253lw as my main screen and have had both operating in the past at the same time.
Please check your plug if it is plug in properly or firmly. Locate the switch and turn it on again. If stil persist, try to inspect whether cpu is beeping while turning on. If its beeping something is wrong in your cpu or monitor depending upon the beeps.
Jan 27, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
My Samsung syncmaster 730a monitor wont come on. the green light is solid but screen is black. could i have done something or might it have gone bad?
Hi friend,
You need you check your display cable. it should be connected in your CPU. sometime cable lose in CPU..then monitor not given any display ...
Dec 20, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
When I start my CPU, I hear a sound that shows me that the equipment is on (that it's working), but the screen stays completely black, no light, no image on it. It happened all of a sudden. I switched it...
that iis not clear from wheryou heare sound.. monitor or cpu. if u hear sound from cpu your cpu fan is not working properly.. that cause processar may be damage,2/ some time damage ram shown same type symtom.change it to find outfault.
Jun 15, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I have a Samsung SyncMaster 793.its qwidth is not normal..
Check its B+ supply line it could be low voltage problem. Or check it other component connected to h-width circuit could be a short in transistor, diode or dried up capacitor. Also resistor for overresistance than marked resistance.
What its B+ supply. From schematic I found, I could assume its around 80Vdc.
Can you post its chassis number.
Mar 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung 710V - controller box
your monitor's video section is fault change video amp. ic or check cpu cable(vga cable).
Oct 20, 2007 | Samsung 710V 17" LCD Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
513 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
