Question about Toshiba Satellite M65-S809 Notebook
Cant connect to my wireless network toshiba m65-s809 laptop used to have mshome now have netgear
2 Suggested Answers
priyabrat
  • 123 Answers
SOURCE: WIRELESS SETUP CONNECTION FOR TOSHIBA TE2100
Go to the control panel. Open wireless connection wizard and configure it by giving the proxy setting of the router. There must be a DNS server to get you connected with the Domain.
First your os xp or vista
if u xp means go to network connection and see that tab, wireless network wizard and click next to open to next to next and click finish. It will appear in network connection windows. But u want to take airtel broad band wireless net key, and u open the tab if u finish ur network wizard tab. And it will open the icon it ask for key, u give it key to continue. It will ready to access the network, so this is the way
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Jan 30, 2008
Passphrase or code to set up netgear router
It sounds like you are setting up or getting into a Workgroup and not a router configuration. To set up your netgear router would not ask you for a passhprase for mshome unless you set the router's SSID to be mshome. Normally the router's SSID will be Netgear or Default unless you changed. During setup you should go into the router's wireless configuration and change the SSID to something such as Your Last Name (ex. Smith_Network) and then set a password under security. If I were you at first I would not set a password. You can always log back into the router and set the password for wireless security later. Just make sure you can see your network SSID from the laptop and try connecting. If it connects then you can go back and set the wireless security.
Mar 19, 2012 | Toshiba Computers & Internet
My Toshiba Satellite M65-S809 Laptop will not turn on! However it turns on randomly sometimes when i toy around with it, but that happens rarely. I tried removing battery, and cable to take out the static,...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 18, 2011 | Toshiba Satellite M65-S809 Notebook
Cant hook on to my wireless, it says to turn my switch on but it is on
on the left side of the laptop towards front .. there is a wifi catcher switch , you need to turn that on .
Thumps up if this works .
Aug 04, 2011 | Toshiba Satellite M65-S809 Notebook
Largest capacity hard drive I can upgrade to, specs
Dear Friend,
Can you be more specific about this issue?
Thanks!
Feb 20, 2011 | Toshiba Satellite M65-S809 Notebook
I just had a white 1" wide white bar apprear on
Try to update your screencard driver
here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
You have to pick your model number
Hope this solves your problem
Feb 16, 2011 | Toshiba Satellite M65-S809 Notebook
LCD is back lit but no image, just black. It works sometimes and the laptop works fine if it's hooked up to an external monitor.
Sounds like the Screen is on its way out.
If you have the ability to set it up as a dual screen, and use your laptop as the main and your external monitor as the extended screen.
Dec 15, 2010 | Toshiba Satellite M65-S809 Notebook
Wireless networks not found
Sometimes Satellites get a little flaky when on battery power. If you haven't already, plug in the power cord with the notebook cold - meaning off for about a minute. Boot the notebook and try to do the setup with the power connected. If that solves it, it should work fine when you switch to battery power. If it doesn't, repost with your results.
Jun 11, 2009 | Toshiba Satellite M65-S821 Notebook
Lost sesktop icons...security threat
Its highly unlikely you'll get a free answer on this web-site, so it's either fork over the money to these jokers or get an answer for free on another forum.
May 25, 2009 | Toshiba Satellite M65-S809 Notebook
Forgot system password
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
Mar 19, 2009 | Toshiba Satellite M65-S809 Notebook
My notebook is completely blank. No response.
Try reseating the memory in your laptop. If this doesn't work then take out the battery and only hook up your AC adaptor to turn on the laptop. If neither of these work then your motherboard is bad.
Feb 05, 2009 | Toshiba Satellite M65-S809 Notebook
Toshiba Satellite M65-S809 Notebook Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
