Question about LG Washing Machines
Hi. I am having LG - Fuzzy Active WF-S6562DN. In WASH mode its not even turning and a small sound comes. Its RINSE and SPIN are working.
5 Suggested Answers
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
  • 257 Answers
SOURCE: LG 8kg Fuzzy logic top
Assuming the water is coming in even when unit is unplugged from wall. You should to replace the water inlet valves where the hoses connect to the machine. You need to unplug the power and remove the top, disconnect the hoses unhook the wire harness plugs, unscrew the hose valve hex nut and remove valve. Install the new one in reverse order.
Posted on May 16, 2011
caroldon
  • 17129 Answers
SOURCE: Our LG Fuzzy Logic 8.5kg
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Posted on Jul 08, 2011
caroldon
  • 17129 Answers
SOURCE: Dear expert of LG WF-F783PC (washing machine). i
Possible that the inlet flow is low , check the inlet valve and filter. Also try using the manual settings and if all the cycle works well then it is possible that the fault is with the controller unit or a possible errors from the level controller or the inlet valve.
It is best to remove them , check reset after cleaning.
Posted on Nov 05, 2011
HI WHEN USING THE FUZZY CYCLE THE MACHINE STOPS AFTER THE SPIN AND RINSE FUNTION. WATER CONSTANTLY RUNNING OUT
pressure valve stuck...remove lid............look for small plastic unit with a thin pipe connected to it......remove small pipe and blow through it a few times
cheers
Nov 21, 2016 | Washing Machines
HOW DO I FIX ?
sounds like the timer has decided not to work . repairman might be a best choice .
Dec 13, 2015 | LG Washing Machines
Our LG Fuzzy Logic 8.5kg washer, model WF-T855A is not working in Wash or rinse mode - noise but no movement - Spin cycle OK. Have had periods in the past where water is not evacuated.
Jul 08, 2011 | Washing Machines
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Apr 07, 2010 | LG Washing Machines
I have a Brand LG Top loader washing machine (Fuzzy Logic WF-T9235TP), it continue draining the water even if I am starting to wash
Dec 20, 2008 | LG WFT1071TP Top Load Washer
WFT7016PP
I have a LG WF-T 7016PP it does not want to go from wash to rinse to spin. I must manualy take it through all the stages. It works perficly on all stages but just does not want to switch over automaticly.
Oct 14, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
54 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
