Question about Excelstor Technology J880 Hard Drive
Jumper setting of excelstor hard disk j880 to master
SOURCE: maxtor 40gb hard drive
i think it's a conflict with the two hard drives maxtor (ata) and westen dig(eide) ,.....could be wrong....maxtor 40gb....west,260gb let me know
Posted on Sep 17, 2007
raevenzero
  • 53 Answers
SOURCE: Maxtor 52049U4 20GB hard drive jumper settings
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
Posted on Nov 12, 2007
SOURCE: system not detecting hard disk
how to recover data from corrupted external hard disk???????
Posted on Jul 31, 2008
preachw996
  • 1179 Answers
SOURCE: pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
Posted on May 23, 2009
  • 173 Answers
SOURCE: jumper setting
ok
check your ide connectin that blue end of ide cable always at motherbord .also check that your ide cable is working properly.
Posted on Jun 23, 2009
Can we use Excelstor Gstor as a Slave Drive? If yes, how? What is the jumper setting required?
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
Mar 20, 2011 | Excelstor Technology J880 Hard Drive
How to make the J880 to slave
you can read the jumpersettings here.
http://dl.dropbox.com/u/599106/Festplatte%2080GByte%20Excelstor%20J880.pdf
The file is in german. Comments are in english. Use only the red framed settings.
best regards
Josch
Nov 14, 2010 | Excelstor Technology J880 Hard Drive
How to format excelstor hardisk?
For your specific operating system, assuming that Windows is running, locate Admistrative Tools -> Disk management.
You should see Disk 0 or Disk 1 with your Excelstor 80GB drive: if you do not have a partition, create one or more partition, assign drive letter(s) and then format using the context menu.
If you do not see the drive in the Disk Management screen, then your Bios has not been setup properly or your drive is not connected properly.
Hope it helps.
Sep 27, 2010 | Excelstor Technology J880 Hard Drive
Pin connection for 'master ..slave
May 23, 2009 | Excelstor Technology J880 Hard Drive
Internal 80gb harddrive excelstor j880
Was this 80GB cloned (copied) from an old 30GB disk?
Open Computer Management window doing this:
Start button - settings - control panel - administrative tools - computer management.
In the window that open, on the left hand side pane, expand Storage and click Disk Management. On the left hand side window, lower pane you should see a list of disks. See Disk 0,Basic <disk size>, Online. Do you see the 80GB as disk size? To the right you would see a series of boxes. Probably you see (C:) 30GB NTFS Healthy (system). Do you see to the right of it a box with 50GB (unknown partition)?
If so, you do have a 80GB disk, but only 30GB is a recognized partition by Windows. You can still use the the unknown partition. Post back here if you need instructions.
Dec 31, 2007 | Excelstor Technology J880 Hard Drive
System not detecting hard disk
Check the position of the master/slave jumper on the drive.
Oct 06, 2007 | Excelstor Technology J880 Hard Drive
Excelstor Technology J880 Hard Drive Logo
1,692 people viewed this question
Top Excelstor Technology Computers & Internet Experts
Elise Lacoursiere
Elise Lacoursiere
John Anderson
John Anderson
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an Excelstor Technology Computer and Internet Expert? Answer questions, earn points and help others
