Question about EuroTech Dishwashers
Hi, Our client has an Euro Tech DW 67 dishwasher. The door is stuck so we cannot open the door anymore. Can you inform us how to solve this problem. Thanks Reinout
SOURCE: Belling IDW 603 dishwasher
You can cancel the programme at any point by holding down the last button on the right hand side for about 10 seconds until it clears (its the same button you use to get it going again when you open up the door).
Posted on May 11, 2008
  • 409 Answers
SOURCE: dishwasher doesn't clean dishes
hi carol,
sounds like the d/w does not run through the rinse and dry cycle. do you have a timer on your d/w or a digital display?
Posted on Sep 13, 2008
  • 4 Answers
SOURCE: Motor runs when door is open- water does not come in- seems stuck
depending on the brand and mdl the unit may be equipped with an overflow safety. If ther is water under the dishwasher in the floor pan then the sensors will trick the dishwasher into thinking it is leaking. Check under the kick plate . if it is moist then take a hair dryer and dry it up up until there is no moisture at all. This should cancel out the pump command and you can start over .
Posted on Jun 13, 2009
  • 4088 Answers
SOURCE: asko dw 95.2 model 1705 after 6 years of use the
Check the level and tightness of the slide rails--they may have come loose after the years of use. Make sure the dishwasher case itself is level. Hope this helps!
Posted on Jun 29, 2010
Testimonial: "Thank-you. The unit is perfectly level. The rails are spot welded and all bearing seems to be OK. Nothing to tighten, will investigate further now that I see the system is not complex at all. Thanks for replying so quickly. k"
  • 239 Answers
SOURCE: Before I started my dishwasher,
The water inlet valve is faulty. When you open the door, it should cut power to the valve, so your valve must be sticking open.
Kelly
Posted on Mar 24, 2011
Having great difficulty opening the dishwasher. no real lever to open.
That's some pretty sketchy information to try to base an answer upon, but having just installed a DW and encountered a similar issue, let me offer this.
While I was doing my install, I encountered difficulties with an uneven floor, semi-rotten floor and subsequently, leveling the front leg adjusters was a challenge. At one point, substantial differences in the adjustments caused the entire body of the DW to become slightly distorted from "square", resulting in the symptoms you describe.
something to check!
Sep 28, 2014 | Whirlpool WDF750SAYM Gold Series...
Rinse only error, interrupted cycle
Double check that the float on the basin isn't stuck. It is mushroom shaped and inside the DW. Open the door, slide out the bottom rack, and look for it. Found it, great. Gently move it up and down a couple times. Does it move freely? Was it stuck? No? Ok Then lets try something else.
Call the manufacturer and ask them questions. If it is less that a year old, it is covered under basic warrantee. Do not delay.
Also check other common issues with DWs: Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Jan 11, 2014 | Frigidaire FGHD2455LF
My dishes are not getting clean anymore! It's extremely frustrating. Also, sometimes my soap doesn't even dissolve! This dishwasher isn't very old, but I am tired of it!
hi, This is a water temp. problem. The first fill s/b about 125-140 degrees. You can try running your hot water tap for several minutes. Run a load, see if there is some improvement. Next, go to your water heater, see where the setting is. On a gas move dial up a notch. On electric remove top and bottom covers and do the same thing. You also need to clean the dw off and on. Take a gallon of white distilled vinegar and pour the whole gallon into the dw after it has started and run for awhile. Then open the door and let sit overnite, starting the next morning. Hope this helps.
Jan 17, 2011 | Whirlpool Dishwashers
Pump will not shut off even with door open
Hi, There is a float under the dishwasher to protect from flooding... If there is a leak and there is water under the dishwasher in the pan then the float switch will turn on the drain pump...
first I could remove the toe panel check in the pan for water... if no water still check the float it maybe stuck up (soap can get under the float and hold it up)
remove water and make sure float in down... if not you may need a new float switch...
Sep 28, 2009 | Bosch Evolution 800 SHE68M05UC Stainless...
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
No water
Mike,
It's possible that your flood/safety switch inside the DW is stuck. Open the door and remove the lower rack. You'll see it right there in front. Lift and drop it several times to clear any debris. (It has to be all the way down to allow water) Now try your DW.
SG
Mar 27, 2009 | Crosley 24 in. CDU600 Built-in Dishwasher
Water leaking onto the floor
1. If the water is going onto the floor during the drain cycle there is either a hole in the hose or it is completely loose from the DW or a hole in the drain assembly under the sink but if that were the case you would have water under the sink also.
2. If it during the wash or rinse cycle then the seals are not sealing (door is not closed all the way or seals are bad) or the float at the right front of the DW is stuck allowing the DW to overfill with water.(you need to open the door and pull the float up and out as you do so push it up and down and listen for a clicking sound.(which indicates it is making contact with the fill solenoid)..if you here the clicking and the float is full of gunk (old soap and such) clean it out and replace it and run it through a cycle and monitor the DW to see if the fill cycle shuts off before the water reaches the overflow point.
3. the only other option is a possible rust through on the DW and or the drain and motor mount in the center of the DW where the food particles and water are drained...is loose and leaking or rusted through...(how old is the DW).
4. Also check to see there are no large particles around the door seal to prevent complete closure and sealing of the door seal. As well as the door latching properly (when closed can the door be moved or pulled open)?
I hope this helps and let me know if not Please relay model number, age and other specifics you feel are pertinent...thank you and please rate me if this helped...thanks again ...the Fang
Jan 24, 2009 | Maytag 24 in. MDB4000 Built-in Dishwasher
Dishwasher doesn't clean dishes
hi carol,
Aug 21, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
KitchenAid 24 in. KUDI01FLSS Stainless
Open the dishwasher door, press in rapid sequence the following keys: Hi Temp Scrub, Energy Saver Dry, High Temp Scrub, Energy Saver Dry. Close the door until it latches and press the Cancel key. The machine should reset itself. It worked for me when I had the same problem
Oct 20, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
32 people viewed this question
Top EuroTech Dishwashers Experts
Tony Houde
Tony Houde
Tom Chichester
Dave Glabb
Are you an EuroTech Dishwasher Expert? Answer questions, earn points and help others
