Question about Whirlpool ACQ108XL Air Conditioner
It will not kick back on once it kicks off. - Whirlpool ACQ108XL Air Conditioner
    President:
  • 3,773 Answers
Sounds like the compressor is getting too hot. High head pressure can cause this. A quick test is to lay your hand on the compressor. It should not be too hot to keep your hand on it.
You may have a restriction of the freon in the condensor.
Also you can replace the relay with a hard start relay.
Ask your local Appliance parts store what a hard start relay is.
also Clean outside condensor coils.with a good coils cleaner.
You can pick that up at your Local Appliance parts store too.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 24, 2010
How to hook up kick down linkage on 1965 ford v/8 automatic?
Well there's a kick down rod or linkage that runs from the carb linkage to the kick down arm on the trans. Once that is on there should be a little spring that holds the weight of the linkage off of the kick down arm on the trans. That spring is at the carb end. Once you have it hooked up you can drive it and adjust to desired kick down feel.
Jun 25, 2014 | Google Computers & Internet
Draind and filled my hot tub (cal spa). electric heat. once i filled it back up and turned breaker back on. when the heater kicks on it kicks out the breaker.
When you drain and refill most spas you will get an air lock in the plumbing. You will need to find the drain valve and open it to flood the pipes. It's possible you may have burnt the element and may have to replace it. Hopefully the breaker kicking spared you this expense. Myself I burnt two of them before I learned. Good luck.
Oct 06, 2010 | Pool & Spa
On my 72 spitfire the starter stays engaged flywheel is new
I would suspect the "bendix drive" in the starter. That is the part that slides the gear into the flywheel when you turn the key. The flywheel kicks it back out once the engine starts but sometimes when they go bad instead of kicking in they refuse to kick out. Hope this helps.
Sep 21, 2010 | Triumph Tr 7 Cars & Trucks
Yamaha ty 175 will bump off ok then will kick off
Sounds as if it needs a tune up. Sorry, can't help with a manual. Start with cleaning plugs and work through.
Dec 30, 2009 | 2005 Yamaha DT 125 X
77 fxe kicker slams back when started and the clutch is pulled in . replaced thrust bearing and the kicker gear stop was snapped off.. replaced and re assembled per shop manuel..?
all kick starter kicks back when starting just give it a little keck like just push dawn on the kick starter to wear it just turnes over 1once than jump on it than it should fire without kicking back but kick it hard or it will kick back
Dec 05, 2009 | Harley Davidson FXD Dyna Super Glide...
Furnace kicks on once and that is it
remove thermostat and then connect red and white wire, if works ok then replace t-stat
Oct 24, 2009 | Heating & Cooling
Yz 250 4-stroke It's extremely hard to kick over, so it has a pressure release lever on the handle bar. Is there some "proper" way to kick it over, or do I just kick it while holding the "pressure rel
That lever is a compression release and pulling it will make kick stating an excersie routine. Kick start without the pulling the lever. See how that works. good luck.
May 29, 2009 | 2004 Yamaha YZ 250 F
Very hard to kick start
i dont know what your timing is relevant to flicking the compression switch and kicking, but get the engine to the compression stroke and then as you go to kick it hard, flick the switch at that moment. timing is everything. i had an old yamaha tt 500 that kicked back so hard my foot slipped off the kick start and kick lever came up and took the skin off my shin.. it took quit a bit of time to get the timing but once i did, it was easy.. hope this helps.
May 19, 2009 | 2005 KTM 640 LC4 SM
RS2577SL plastic ice tray once ice is made kicks out
http://www.apwagner.com/index.php?main_page=part_finder
looked up picture of ice maker everypart listed and saw a broken piece ordered it 20K on samsungparts.com
part was less then this site. but at leats you can look up diagram with parts list
Mar 27, 2009 | Samsung RS2578BB Side by Side Refrigerator
Whirlpool ACQ108XL Air Conditioner Logo
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
