Question about Refrigerators
The refrigerator is still functioning, but even adjusting the temperature control does not make it cooler ... we have clean the coils underneath, but it has not appeared to help . There are not odd sounds and I head the compressor run, but basically it appears to run pretty hard and cool thr fridge and freezer down, then it waits too long to come back on again and things in the freezer start to defrost before it starts again. Compressor on bottom back is hot and I noticed the vinyl flooring below appears burnt a little, that may have been like that for a long time though. Amanda 1999 TN21V2w
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
The Refrigerator's Freezer is not working but the fridge is, what is wrong?
You probably have one compressor that cools the freezer section and the refrigerator section. Usually the freezer gets cooled directly with the cooling coils. A fan blows cool air to the refrigerator section. The air flow to the refrigerator may be modulated with some time of "air door". What you have written says to me, is that the fans and air doors are working but there is enough cold for the refrigerator but not enough for the freezer.
Here is what I would do:
  1. Put a thermometer in the refrigerator and in the freezer.
  2. Be sure the coils underneath or behind the refrigerator are clean. If they are very dirty, clean them.
  3. Keep the doors shut for at least 12 hours and then read the thermometers and write down the temperatures.
  4. Freezer temperature
    1. If the freezer has started freezing again, you fixed it by cleaning the coils
    2. .If the freezer temperature is between 0 deg F and 32 deg F, consider putting the food in a cooler and packing in some dry ice to try and save it.
    3. If the freezer is warmer than 32 deg f, throw away the food.
    4. Doctors and hospitals are pretty expensive. I would throw away the food no matter what the thermometer read.
  5. Look inside the freezer at the cooling coils. See if they are ice coated or not.
    1. If the freezer is above 0 deg F, and the coils are ice covered, the defrost control is not working. Unplug the refrigerator for 12 hours and let the ice melt. (Keep the doors shut.) Then, plug in the refrigerator for 12 hours and check the temperature like in step 3.
    2. If the freezer is above 0 deg F, and the coils are NOT ice covered, the compressor is not working.
  6. Call the service technician. When she comes out show her the temperatures and tell her what you found out about the ice on the coils.
Good luck
Jun 07, 2015 | Refrigerators
Temperature in both upper and lower zones will not go lower than 50F. Cooler has 3 bottles of wine. Is there away to recharge with coolant/clean fans...? Thank you
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor.
Before cleaning the condenser coils, unplug the refrigerator to avoid a shock hazard.
Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.
Jul 10, 2011 | Danby DWC283BLS Wine Cooler
I cannot adjust the fridge/freezer temperature
Hi, there
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
How can I adjust the temp. on a norlake walk in cooler?
There are many variations for a Norlake system
I assume the cooling coil hangs from the ceiling of the cooler and the condensing unit sits on the top?
The temperature is controlled by a control that is located in the condensing unit on the top of the cooler. This can be either;
\ a digital thermostat. You will need the progam key to get in
\mechanical thermostat. Adjust the dial setting
\ pressure stat. Adjust the dial setting
Probably best to get a technician in
Apr 22, 2011 | Refrigerators
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Jan 08, 2010 | True TBB-2 Beverage Cooler
The compressor on my Sears Coldspot is running at 175 degrees.
Refrigeration compressors used in domestic refrigeration are known as high side compressors, meaning the dome is at high side pressure and temperature.
As long as the condenser fan was running, and the coil was as clean as you could get it, then all is OK. There is no standard temperature that it runs at, and it has been tested to run hot anyway. The fact that you cleaned underneath will allow it to run a little cooler anyway.
Jan 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator freezes things the freezer works fine:
Most common is a dirty condenser coil. If you have not cleaned it recently vacuum and brush the coil underneath and the back bottom compressor compartment. Blocked air flow will cause erratic temps in the refrigerator section.
Jul 28, 2008 | Jenn-Air JSD2789GES Side by Side...
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
