Question about GE Refrigerators
GE TFX25CR side by side refrigerator. Center dividing piece between refrigerator and freezer is burning hot at front where doors close. All else is working. How can I fix?
  • 1314 Answers
SOURCE: Kitchenaid Side by side refrigerator/freezer
when is the last time you cleaned the condenser coils the areas you describe are supposed to be hot there is a loop there to keep the door gaskets dry but should not be too hot pull the fridge out check to see if the fan is running on the compressor then unplug the unit and clean the coils the only other thin that will make it super hot if there is a leak in the low side of the system and has drawn air in see if cleaning the coils fixes it first and we will go from there
Posted on Feb 13, 2008
SOURCE: Center Column is getting Hot
My side by side divider/column was getting really hot to the touch. The freezer temp was at 8 degrees and climbing. Vacuumed the front grill but not much space to clean. Pulled out the refrigerator and there was all this lint clogging the grill where the compressor and fan was. Took the grill off and clean compressor, and the whole area was dirty. Before moving it back i checked the temp. and had begun to come down and the hot spot was not hot anymore. I will mark on my calendar to make it routine to clean it Spring and Fall. After all it's been 4 yrs. since I got it and my fear was scratching the wood floor under it so i procrastinated finally the husband gave me a hand with it. Thanks for having this info available. It saved me some money$$$.
Posted on Mar 14, 2008
  • 1462 Answers
SOURCE: Whirlpool Refrigerator Door Seal surface is HOT.
transom between fridge and freezer is usually haeted to stop condensation when you open freezer door. suspect you have no fault
Posted on Jul 14, 2008
Krazytech
  • 725 Answers
SOURCE: center divider between refrigerator and freezer
check the fan in the machine compartment...if the fan is not turning when the compressor is running you have a bad fan motor. this caused the youder loop to over heat trying to cool the condencer...hope it helps
Posted on Sep 19, 2009
aasc
  • 1606 Answers
SOURCE: GE Monogram ZISB36DYB Freezer Not Cold Enough; Burning Center
Pull the refrig out , and remove the panel at the bottom , on the back . Behind this panel , will be the compressor and condenser " roll " coil , and the condenser fan motor . From your description of the problem , the fan motor in not operating , or the coils are extremely clogged with dust . If the fan motor is not operating , the most likely cause , is the main control board . You can try replacing the motor first , but , the board is most likely the cause . This is the electronic board , behind the 8 " X 10 " panel , behind the refrig also . If you remove the panel , and look at the board closely , You may see a burned part ( resistor ) . However , replacing the burnt part , will not solve the problem . The complete board will need to be replaced .
Posted on Oct 14, 2009
I have a KSSC48QMSO1, The center panel, that divides the freezer from the refrigerator is hot to the touch at the top end and only where the side doors close together. Also the refrigerator is not holding...
could be a problem with a dirty condenser or your condenser fan may be no good. That will cause the center panel to be hot and will prevent the refrigerator from cooling properly. Is the sides of the fridge hot to the touch as well?
Mar 18, 2011 | KitchenAid KSSC48QMS Side by Side...
Why wouldthe center piece between freezer & refrigerator get hot
There is a heater located behind that strip known as the mullion heater.
Look to see if you have a switch labeled "anti-sweat"
Apr 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Freezer and refrigerator are not cold enough.
you problem check and see if your fan condeser working best call service
Mar 22, 2009 | Kenmore 53092 / 53094 Side by Side...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Feb 13, 2008 | Refrigerators
Samsung side by side center divider front extremely hot
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
Aug 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
