Question about Jensen's VM9312 Car DVD Player
Vm9312 jensen dvd bypass
Is it possible to enter th bypass code without the remote?...I don't have a remote.
I just hooked the pink wire directly to the same ground spot as the head unit and it works fine
Posted on Jun 05, 2008
Brake bypass without remote
My Jensen play on and off but it's on on the face
Jan 12, 2014 | Jensen's VM9312 Car DVD Player
Vm9312 how to bypass parking brake if i don't have the remote bought it from pawn shop didn't know about it having remote anyother way
im in the same exact situation, if anybody has an answer, can you PLEASE email me?? lethalxremedy@hotmail.com
Apr 20, 2010 | Jensen's VM9312 Car DVD Player
How do i by pass parking brake wire for indash dvd jensen vm9312 i'm puting it in old car no p.b.
Hi jason
To answer your question;
You do not need to connect that wire but you need to bypass the parking brake function in the menu.
Here`s the parking brake bypass procedure:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Hope this help Cheers
Do you know the bypass for this radio vm9312
You can try the procedure for the VM9311TS model (the one I have) - I don't know if it'll work but it's worth trying. Put in a DVD, and let it start playing. Then hit STOP on the remote twice, and enter the code 1264. If you were able to see the actual movie at this point, you'd see a menu pop up. Push down twice, then ENTER. At this point the blue screen should clear and you should see the movie itself. You'll have other options on that menu, like a macrovision option to allow you to see burned DVDs. Set what you like, then on the remote, hit SYS SETUP twice to lock in your choices.
Nov 13, 2009 | Jensen's VM9312 Car DVD Player
Bypass parking break feature on the Jensen VM9311TS
You can purchase an aftermarket bypass kit from electronics store or off ebay... But hey, be careful, no watching movies while driving... K
Jun 05, 2009 | Jensen's VM9312 Car DVD Player
Emergency brake wire connection
Here's a Bypass to solve that. Turn your 9312 on and set to radio then Using your remote enter 543210 and make sure you hear a beep each time, a new menu screen will pop up, click the hammer and screwdriver on the upper left side,Next press the menu line for brake override, a sub menu will appear, select ON,Press the X at the lower left of the screen and you're done enjoy and be safe.
Apr 12, 2009 | Jensen's VM9312 Car DVD Player
Jensen vm 9312 region code
You can get into the master system by using your remote. 1.Make sure your Jenser VM9312 is on, and select AM/FM as your source. 2.On your remote, press the Setup button, located on the lower right of the remote, you should hear a beep from your VM9312 when you press the button. 3.Now, making sure you hear a beep after every key press, press, 543210. NB:If you did this correctly, a new menu screen will pop up. 4.On the display, press the hammer and screwdriver icon, located on the left hand side of the screen.
NB: Here you can bypass the break and regions etc. When done Press the X at the lower left of the screen and enjoy.
Feb 01, 2009 | Jensen's VM9312 Car DVD Player
JENSEN VM9312 CAR DVD PLAYER HOW
go to am/fm
then open the settings screen
next on your remote type 5,4,3,2,1,0 listening for each beep
a new screen should come up
after that look for brake override
Mar 19, 2008 | Jensen's VM9312 Car DVD Player
How do i do to bypass my jensen vm9312
go to www.ecoustics.com then click on forum at top click car audio then multimidea. and read Teir are bypass codes for several models here.just have to look for them.
Dec 18, 2007 | Jensen VM9510 Car DVD Player
Vm9312
That is the code for the older jensen's The parking brake bypass procedure is as follows: 1: Go into AM/FM mode 2: Hit "setup" on the remote control 3: Enter 543210 on the remote, listening for the beep for each number entered 4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen. 5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
May 25, 2007 | Jensen VM9510 Car DVD Player
Jensen's VM9312 Car DVD Player Logo
741 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
