Question about Proform Exercise & Fitness
The walking belt jars when running fast. Also I want to know how to lubricate it. Anyone with a manual? Please help?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
Follow the directions below to determine what is slipping. You also can get a copy of your manual by going to iconservice.com and downloading one from the manuals tab. Here are the directions for testing the slipping problem.
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft
* then try to walk on it and see if the white mark separates
* if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place
* if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix.
* if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws.
Tighten each one the same amount such as 1 full turn to start with.
see if you can now walk without it slipping.
If not then tighten 1-2 more turn on both sides.
If after 2-3 full turns it is not tight enough
I would recommend replacing the walk belt.
Hopefully this helps with your problem!
Posted on Aug 25, 2010
I have a bowflex TC3000 treadclimber and it is making loud humming/whirring sound.. any idea how to resolve this? thank you
Try to lubricate the Running belt first.
check the video to know how to lubricate the running belt.
Treadmill walking belt lubrication
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 25, 2016 | Bowflex Exercise & Fitness
Treadmill doesnt seem very fast
Run the software calibration for easy diagnose, and fix it.
However LUBE the deck belt with silicones or was. Read your owner manual, for to see what lubrication is your machine.
God bless you
Jun 04, 2013 | Weslo Cadence TS 310 Treadmill Motor...
My treadmill walking belt move but when I stand on it it stops, but the motor is on
Dear Sir:
This a problem from worn deck vs deck belt.
The cause is lubrication and lack of maintenance. That produce enough friction, that design of electronic system shut down the machine for to protect the electronic design.
Lubricate in according with your user manual, section Maintenance.
Try to run the software calibration for easy diagnose and trouble.
See my personal TIPS for help.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
Mar 21, 2012 | Exercise & Fitness
My treadmill turned on but the belt will not run
Dear Sir:
If the treadmill is turned On, you must check the follow:
1) the belt drive motor is faulty. 2) loose tension in walk belt, tight it.
3)Roller bearing from walk belt is faulty(lack of lubrication) both extreme.4) Walk belt is faulty and NEED LUBRICATION.
Please RUN the software calibration, under the Hood of motor and see the steps, for diagnose and troubleshooting.
See the block diagram attached. for help in troubleshooting.
2_16_2012_9_40_01_pm.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Exercise & Fitness
I have an IRONMAN 220T treadmill and have a code # E11 and I do not know what it mean, can anyone help me with this.
E11 Means that deck bel or walk belt is slower speed that speed window .
2 possible causes:a) Locked rotor from main motor b) High friction from deck or walk belt.
3) Use the calibration software from your equipment for easy diagnostic and correction.
4)Use the owner manual or your step under the Hood ,and proceed with the steps indicated.
5) You can lubricate the Deck or Walk belt. please see your owner manual section: Maintenance.http://www.youtube.com/watch?v=f7IZWMMrCM0 please see this videos for easy help in lubricating. and adjusting deck belt treadmill.
http://www.youtube.com/watch?v=AZSMLpXm-tA
sincerely. Merry Chrstmas.
ernesto cuadramanagua, nicaragua.c.a.
Dec 22, 2011 | Ironman 220t Programmable Treadmill (225...
I have a nordictrack 2500r treadmill and when i run on it the belt sticks to the board underneath. Any assistance would be very much appreciated thanks
hi,
Your treadmill walking belt need lubrication. For lubricating use Teflon silicon lubricant. To know how to lubricate the treadmill belt watch the following video.
OK
Aug 20, 2011 | Exercise & Fitness
The belt on my running machinet207 is sliping when you stand on it
Jo,
The most common cause of belt slippage is lack of lubrication. Most treadmill belts use lubrication on the underside of the belt to reduce friction between the belt and the platform. This helps the treadmill glide along smoothly under the weight of a person. If your belt is lacking in lubrication, it can catch on the treadmill platform. Apply lubrication every few months to the underside of the belt to prevent this from occurring.
A petroleum or silicone based lubricant is recommended, and most easily applied in a spray can. Simply lift up the belt about midway along the platform and spray a small amount of lubricant underneath from about the middle of the platform width to the closest edge. Repeat from the other side. Apply lubricant sparingly...it can be messy.
Next, turn on the treadmill and let it run for a minute, then check if the belt still sticks. A little more lubricant may be necessary.
Hope this helps.
Regards,
DIYpro
Apr 27, 2011 | Sport & Outdoor - Others
What should I do if the treadmill walking belt slows while in use?
Sounds like your walking belt is starting to get worn,.or you need to lubricate the walking belt. Try applying a silicon lubricant, or other lubricant called for in your manual, to the bottom side of the walking belt, and the surface it contacts. ( not the drive roller).
Jan 28, 2010 | Exercise & Fitness
I have a Lifestyler 8.0 Treadmill. It keeps
Use a good silicone Spray under the belt for every 10 hours of use
Jan 02, 2010 | RTO Lifestyler 8.0 MPH Treadmill Walking...
Treadmill may be slipping
Depending if this is a new issue or old, It could be a couple of issues. Check the belts for slipping. Proper tension on walking belt (check your manual) or drive belt -remove the cover and you might be able to see if the belt is slipping or it could be a load issue (electronics not sensing added load fast enough). My bet is belt tension. Also Lubricate,lubricate,lubricate
www.twincityrepair.com
Feb 28, 2009 | Reebok Exercise & Fitness
Exercise & Fitness Logo
125 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
