Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43 / Siemens Dishwasher door not locking
My door latch doesnt stay locked. After I take the lock off to reset it, it only takes about 5 - 7 times for the latch to go bad. I took off the screws, the power contact switch, and then the lock to push in the spring and rotate the nylon clip to its proper position. All seems ok, but I suspect maybe the screws on either side of the latch is not tight enough, or maybe the frame of the door is not aligned. When the latch is reset, all operations are normal, and there's no leaks. If its the screws, what can I do about it?
  • tomnovice May 13, 2008
    Reply to Solution 1:
    STEP BY STEP IN DETAIL: After you take off the top 8 screws of the inside cover, you pull up a little and the control section of the door comes up and off. Next remove the wired contact switch that is attached to the latch by pushing in the little contact button (its on the bottom - use a small screwdriver to gently pry out the body of the contact switch after pushing in the button). Now the latch can be taken out by using a thin long screwdriver or needle nose pliers to untwist the 2 tabs that are part of the inner control panel frame and are twisted against the latch. You should be able to wiggle upwards and out the plastic latch body by itself. Holding the latch in your hand, push in the plastic covering a spring that is on the hidden side to rotate the lock catch thereby resetting the lock.
    To answer my own question, I lately tried twisting the tabs as tightly as I can against the latch body when installing. So far it seems to be working ok.
  • tomnovice Oct 20, 2010
    I gave up trying to screw with this- replaced lock latch part (available online); that solved the problem.
Posted on May 13, 2008
I replaced the top cover, that required removing the door screws to get access to the front of the door to remove the 4 top cover retaining screws. After replacing all this, the door latch was in teh locked position not allowing the door to close. How do you physically re-set the lock, I tried to push it with no luck!
Posted on May 12, 2008
My Bosh SHX7ER55UC door won't latch. Trying to figure out the 2-screwdriver method but can't figure out what part to push/pull.
HOW TO FIX YOUR BOSH DISH WASHER DOOR LOCK ...
? 11:11
https://www.youtube.com/watch?v=_uPK5mJmvZM
Jul 23, 2013 - Uploaded by Andrew Wallace
Dishwasher Door Latch (part #W10275768) - How To Replace ...Dishwasher Door Latch Replacement - Bosch DishwasherRepair (part ...
Nov 29, 2015 | Bosch 800 Plus SHX7ER55UC Fully Integrated...
Door lock
Pull the door latch towards the front of the dishwasher until it clicks in the open position.
Mar 30, 2014 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher model SHY56A05UC/14 door wont latch. It will run but of course water comes out as it is not locked.
That sounds more like a gasket problem then a lock problem. Check the rubber seal on the door for damage. Even a small imperfection in the seal can cause the door to leak even though the lock is engaged.
Or is it that the door just won't close at all? If that's the case, check the locking mechanism to see if there's anything jammed in there. If so, remove it and that may fix the problem.
Jan 01, 2013 | Bosch Dishwashers
Door will not latch. Unit can be turned on with
you need to replace the door ock mechanism it is stuck in the closed position.you can take a smal flat tip screw driver and try to pull the locking lever back forward this will unlock the switch but when you close the door and try to reopen it the same problem will happen. so just replace the lock
Jun 02, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Our Bosch SHY66C05 door latch is stuck in locked position
you have to pull back the spring or replace the lock. the repair is pretty easy.let me know what happen.
Nov 07, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
How do I remove inner door skin to get at latch of Bosch Dishwasher SMS 2012
you dont remove inner door skin you remove outer, screws along both edges will allow outer door panel removal and the rest around the console will allow that to be detached showing the door latch in all its glory.
Oct 12, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Diswasher wont fill
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Can't close Bosch Dishwasher door
I had same problem and was alarmed at the idea of taking the door apart, so I tried the 2 screwdriver option described below - it works!
Open door and get two small screwdirvers behind each side of the catch inside the top of the door and gently apply pressure. The catch should reset itself on 'open' and allow you to shut the door again.
Thanks to all for their postings and helpful advice!
Nov 10, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
463 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
