Question about Dyson Ball DC24 Bagless Upright Vacuum
I am unable to get the handle off the top to use the hose. what to do?
  • 3 more comments
  • ritaedw Aug 24, 2010
    I am aware of a button on the side only to release handle.The top of the handle pulls out to make the wand to put tools on and sweep.I cannot get the handle off or pull the the wand out.
    I know there is a button on the side of the vacuum to take the handle off. there is also a button on the top where u pull the wand out to put the attachments on and use to sweep with but neither seem to be working?
    I know there is a button on the side of the upright that u have to push to get the handle off, but it is not working. also at the top of the upright u flip open the opening and pull out the wand and there is another button u press to get the wand out of the hose it is not working either?
  • ritaedw Aug 25, 2010
    Your solution did not work. my brother-in-law came over and fixed the problem.
    this did not work . my brother-in-law came over and fixed it last night.
  • 4,924 Answers
Http://www.youtube.com/watch?v=Mm4rFq71zHA&feature=channel
Take a look at this video ..at one point they show how to remove the handle ...On this model it comes out with the bar ..and the hose will extend from inside...It has a locking device at the side..and will probably need a slight rotating move to get it out ..
Posted on Aug 25, 2010
  • Catalin Turcu
    Catalin Turcu Aug 25, 2010
    If it still do not want to get out ..just push that button and force it a little cause it might be jammed..
    President:
  • 2,030 Answers
There is a yellow button at the top of the unit that you have to push to release the handle.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 24, 2010
  • Sean Wright
    Sean Wright Aug 24, 2010
    Twist the handle both ways while pulling and it will come off.
Top coupler on gas pump handle ONLY (Majestic 360 SS) is broken. Do we have to replace whole hose and handle assembly?
They now make a replacement tab so you don't have to replace the entire handle grip. The bad part is, most of the time it's the handle grip that has the broken place in the plastic, not the latch tab. That too can be bought seperately though, so you don't have to buy the hose. Call your local vac shop for assistance.
Oct 21, 2014 | Filter Queen Majestic Canister Vacuum
How do I remove the hose from the handle on a Lux Legacy?
You first have to knock out the plastic "plug" under the bottom of the handle and also pop off 2-3 small screw covers, about the size of a pencil eraser, on the top of the handle. Now remove the screws with the proper jewelers screwdriver or star driver and gently pull the handle apart (top and bottom). Be careful to pay attention to where the wires lay inside the handle then remove the handle from the hose. Voila! There's your answer....Hope that helps!
Oct 11, 2014 | Electrolux Vacuums
Hose is plugged close to the handle. How is the handle removed from the hose and reassembled after the plug is removed?
I don't recommend this for the homeowner. Take the hose in to your nearest AERUS store. It is just too easy to damage the pins and rings putting the handle back on. If you insist on trying, remove the little torx screws under the little buttons on the top side of the handle. Good LUCK and be careful. Don't force anything.
Jun 10, 2010 | Electrolux Centralux Vacuum
My dyson 17 wand does not work. When it is on and you stand it upright it turns off
Hi its Darran at Dyson.
If the suction is good from the base but not from the wand, this would indicate that there is a blockage in the wand handle or hose. To test this, stand the machine upright and release the wand handle. Switch the machine on and test the suction from the top of the wand with your hand. If its poor, remove the wand handle from the hose and try the suction at the top of the hose. If its good here, then there is a blockage in the wand handle.
If the sction from the top of the hose is poor, you can remove the hose to check this for any splits or blockages. If it needs to be replaced, you can buy a replacement online at www.dyson.com.
Alternatively, should you any further help or advice with your Dyson, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have no suction through the tube so unable to clean with attachments. Why?
Its plugged up. Remove hose from appliance, and see if the cleaner sucks. If so, pull hose in a straight line and push a broom handle through the hose to clear debrie. Re attatch hose and this should clear the blockage
Dec 04, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Can the damaged hose 8 inces from handle be cut then replace hose
If the hose is non-wired then you can fix this yourself. When you Plug the cuff into your wall inlet does the vacuum turn on automatically? If so then you should be able to trim the hose with no ill effects other than losing eight inches of cleaning area.
If the hose has a switch on it's handle that turns the vacuum on and off, you will probably need a technician to fix the hose. Some wired hoses even have High Voltage lines in them and should never be taken apart.
Jan 11, 2009 | Electrolux Central Vacuum
Bissell Proheat Clearview 1669
Take out the 2 long screws with the nuts on them, then furher down just beneath the hose wrap asm, there are 2 more screws to remove. Put the top part of the handle off, lay the handle down, on the front, at the top and in the center is a tab, push it in and pull the top half of the handle away from the bottom half. Then you will see the heater, don't mix up the hoses after you are done.
Jun 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Take off the 2 long screws and remove the top part of the handle. Then from the back, just undr the hose and cord wrap asm, there are 2 screws set deep in the holes to remove. Don't remove the cord and hose wrap. Then lay the handle back, at the top, in the center, there is a catch to push in, then the top half will come off and you can get to the heater. Remove the hoses, one of the hose ports maybe clogged, clean them out, sometimes stuff in them gets pretty hard and hard to clean out.
After you may want to run a mix of vinegar and water thru the system to clean it all out.(not on your carpet tho)
Jun 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
Brush motor doesnt work
The cord at the bottom of the power head neck may be bad. But so could the plug connections in the hose handle, and the cord on the wand. Check both ends of the wand and make sure that the plug ends aren't burnt, if they are replace them and maybe the plug inside the hose handle.
Mar 24, 2008 | Kenmore 23613 Progressive PowerMate Bagged...
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Dec 04, 2007 | Vacuums
Dyson Ball DC24 Bagless Upright Vacuum Logo
100 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
