Question about GE Refrigerators
My g e frig is not defrosting mod gss22wgmc cc i check out relay heater replace board still ice up
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Maytag sxs; freezer frosts up no defrost + runs all the time + fridge side is cold.? Thanks.
Try to turn the defrost timer manually to force into defrost. If the frig defrost the ice then replace defrost timer. If unit dose not defrost the ice then check defrost heater and replace if needed.
Oct 26, 2014 | Refrigerators
Have extra older Frig in th garage Mod 596.72232200
Sounds like a intermittent problem with the defrost timer. Sometimes they get stuck. Check continuity of the defrost heater and defrost thermostat. If both are good then replace the defrost timer, that should solve the problem.
May 30, 2014 | Refrigerators
Frig quit working.....unplugged....plug back in and it works for.about 3-4 days then quits working again....did this 4-5 times in a month with the same results. I have replaced the thermostat in the...
have u checke the defrost heaters in the frezzer. also the termnation switch with the heaters.. if they dont work then it dont defrost and it builds up ice and wont work properly. ok
Feb 16, 2011 | Refrigerators
Working on mod. gss20iepd frig replaced def heater and over temp therm ohm thermistors, seem o.k. coil still frosting, before i replace control board, what puts frig in def cycle?
everything goes through the board,when you pull out the board you'll see a gray connector with three prongs,that's the defrost connector on the board
Oct 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Runs continuesly and does not go in to defrost or cool the fridge
hi,on the back wall of the freezer,is there ice...if so you have a bad defrost sensor or heater...if froze up,when you remove panel...if ge replace white sensor on coil an heater at bootom...if regular frig ..replace round disc with two wires on copper tube...if iced up coil..deice with blow dryer,,,unplugg frig first...also check heater...hope it helps....michael doctor airr appl.repair 843-384-8474..call if need assistance..good luck..
Mar 26, 2010 | Refrigerators
Ge frig does not freeze on freezer side
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE profile freezer/frig - frig side has ice on coils
Sounds like the automatic defrost system is not working. The usual problem is the defrost heater, the defrost thermostat, or the defrost timer. If any of these parts are bad, it will not defrost.
Aug 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost in freezer, ice thawed and frig not very cold...what could it be?
If the evaporator coils behind the back panel of the freezerare icing up because of auto defrost failure that will stop the circulation ofcold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control.
Jul 05, 2009 | Kenmore 57029 Side by Side Refrigerator
GE Frig mod#TFX26KPDA
More likely, the defrost system has failed.
There are three components: Defrost timer, a defrost heater, and a defrost bi-metal.
The timer can be located either in the food compartment, on the rear of the unit, or behind the kickplate. The heater and bi-metal are located behind the freezer rear wall (or freezer floor, depending on design). It's easiest to unplug the fridge overnight, with the freezer door open, to melt all the ice that has developed. PRIOR to doing all this, please ensure that there IS ice forming on the wall of floor of the freezer! Let me know. I hope this helps!
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
