When you say you have made all the adjustments, are you referring to the idle speed screw adjustments? If so, have you turned down the High idle adjusting screw? Sometimes these get stripped, and it doesn't end up doing the job it should.
One other thought: If you don't have spring tension on the throttle trigger in the handle, the linkage may have popped off inside. This is kind of a pain in the *** to fix, because there is a spring mechanism inside the trigger handle, and the linkage is a strong bent metal bar that winds its way into the motor and fits into a hole in the throttle assembly, but is not well shown on the parts diagram for the saw from Husky. If this is the case, I can go through the process with you on a followup.
