Question about GE WSXH208A Front Load Washer
GE WSXH208FWW washer leaving spots on clothes
I have this problem with my GE top load machine which was new eight years ago. No problem until just recently when the machine was loaded with a load too large for it to handle. The problem has just recently started, and does not do it all the time, but I did have an idea that it was the bearing. The greasy oil is dark and leaves spots that do not come out, but---I found an odd solution. I rubbed good old Crisco on a lovely piece of clothing and then soaked it in hot water in the kitchen sink. Rubbed somemore. Then I used a bar of hand soap (used Dial soap). Not liquid detergent. And then I. scrubbed the spots with the soap. Washed it out in the sink again-- and lo and behold the spots were gone. I had tried--vinegar, rubbing alcohol, bleach, baking soda and other solutions. to no avail. But baking grease and good old soap did the trick.
Posted on Feb 04, 2013
    President:
  • 670 Answers
If you are getting round dark spots on your clothes after washing, the problem would be cause by a bearing seal leak. What happens is water leaks pass the seal into the bearings, and the grease leaks back into the wash water. To fix it would require the machine to be literally taken completely apart to get to the bearings. Very costly to repair. Sorry.
Posted on Aug 24, 2010
My washer leaves oil spots on my clothes
The only place where oil can enter the wash would be if the bearing seals have failed. It's a major repair, and the entire machine has to be taken apart to replace the bearing and seal.
Jul 30, 2010 | Kenmore HE2 Plus Front Load Washer
Grease Spots
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 25, 2010 | GE WSXH208A Front Load Washer
Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Sep 10, 2009 | GE Profile WPRE6150KWT Colossal Capacity...
Leaving dirty marks on clothing
Try removing the water hoses and find the screens in each end.. If clogged with gunk - that could be the culpret..
Jul 23, 2009 | Washing Machines
Black spots floating on top of water
the top seal in the transmission is bad causing oil to get inside you will need to replace the trans but it will be cheaper to buy a new washer
Jul 12, 2009 | GE Profile 3.5 Cu. Ft. King-Size Capacity...
Wsxh208fww front load stackable washer, spin cycle won't work
It most likely has a bad door safty switch. This goes out and the cycles will not run.
Jun 15, 2009 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
428 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
