Question about Gateway GT5220 PC Desktop
How do i get a c51pvgm gb motherboard to recognize a new sata hard drive.
  • Gateway Master
  • 5,660 Answers
Better get a SATA adapter card, as this mobo uses IDE (PATA) harddrives. http://www.legendmicro.com/store/4761_ECS-C51PVGM-GB--Gateway-4006136R-SK-AM2-2000FSB-DDR2-MBTX-AVL---New-C51PVGMGB.lmsp
Posted on Aug 24, 2010
Just bought a new cpu, put it together and purchased the western digital 160 gb sata II model number WD1600AAJS. i am installing windows 7 on it, or attempting and it won't recognize the drive. it says it...
The drivers are not needed, West. Digital is right. Your problem is that the hard disk is not recognized by the motherboard (not the cpu). Since you didn't mentioned anything about motherboard's brand / model, I have to tell you that you have to get into the bios settings and get yout hard disk recognized by the bios. I assume that the connections are right.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 19, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Not recognized
G'day mate , as i have found in older computers the drives these days are not recognized by the motherboard/ system / is only for smaller drives , i have had to build a new machine and now gone to the SATA drive, hope this helps
Apr 07, 2010 | Quantum Fireball 1.2 GB SCSI Hard Drive
My samsung 40 gb hdd not detectin inany computer after new installation
Is your hard drive a SATA (Serial ATA, a thin cable) or IDE (a fat, usually gray cable)?
If your hard drive is a SATA, be sure that the both the power and data cables are securely connected to the hard drive (and data to the motherboard). Then go into your BIOS and make sure your hard drive is seen by the motherboard. It should read a model number similar to that of the model indicated on the hard drive label.
If your hard drive is an IDE, make sure you've selected the CS (cable select) mode on the hard drive using the correct jumper setting. It should be displayed on the label using a small diagram. If it isn't, you can use the Samsung HDD Jumper Settings page to check the settings. Also be sure the cables are secured, as IDE cables can be difficult to fully connect. If this is the case, try using just the hard drive on its own without any other IDE/SATA devices connected, and see if your motherboard detects it.
Try different cables for either type to make sure it's not just the cables that are causing the issue.
If all the above have been tried and your computer still cannot see the hard drive, you may have a faulty hard drive, motherboard or power supply. Try using your hard drive in a different computer, if it still fails to be recognized, you'll need to replace your drive. If it is recognized, your motherboard or power supply may be at fault. Try a different power supply. If that doesn't work your motherboard may be the issue.
Best of luck.
Mar 21, 2010 | Samsung (SP0411N) 40 GB Hard Drive
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
How to make Seagate ST3200822AS 200 GB Hard Drive
If you are using the drives in a fairly new computer, the drives have a setting called "cable select" If these are EIDE drives, then they have jumpers on a set of pins on the power side of the drive. Look on the drive and use the power plug as a reference for how the jumper fits on the pins to make the drive "cable select" and what that means is the drive will conform to which cable is plugged into it. If you have the slave cable plugged into the drive, that is how the motherboard will recognize it.
Sep 25, 2009 | Seagate ST3200822AS 200 GB Hard Drive
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
I have had to reinstall my operating system and drives but now the Seagate 500 GB external is not recognized. What now?
Are you using eSATA for the External or USB. If it is eSATA you may need to get the respective drivers for your motherboard for it.
Jan 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Sep 17, 2007 | Western Digital Caviar SE WD800JD SATA...
Harddrive
Hi, Looks like it will be a motherboard issue not Maxtor (ATA) and Barracuda (SATA) combination. So the question really would be if your motherboard would accept and recognize the Barracuda SATA. Post back with your motherboard details, (brand/model/version). Kind regards.
Aug 30, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Gateway GT5220 PC Desktop Logo
138 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
