Question about Smeg SE210X/1 Stainless Steel Electric Single Oven
How can I bypass the timer/clock in the oven of model SE210X ? I seems like this timer is nolonger working and needs to be replaced. However, this is quite costly.
SOURCE: FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Posted on Sep 14, 2007
TaPuna
  • 70 Answers
SOURCE: smeg oven model SA708X--Clock faulty
hi, if you have a faulty clock it is likely the relay in the clock is stuffed you could try to repair it but i think you are better off just buying a new clock, clocks are expensive thou, so bypassing is a good choice
Posted on Sep 09, 2008
barkencoa
  • 3463 Answers
SOURCE: creda concept solar plus oven timer
Hold down the 2 left buttons together, and press the + or - button at the same time..
This should reset the timer.
Please leave a fixya rating for my solution.
Thanks.
Posted on Feb 12, 2009
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
EllaWatson25
  • 725 Answers
SOURCE: Need Chambers Oven clock/timer unit, model #GBO-244
I can get you one. Please call me at 9728590929 and I will be happy to find one and ship it to you. Hope this helps! Ella
Posted on Aug 22, 2009
How to bypass broken clock on eurolec 720ef electric wall oven
If you bypass the clock, how will you maintain a steady temperature, include safety features, or program functions?
What you seem to want is an outdoor grill. DO NOT bypass the logic board on your oven, sir. Help Me Find My Model Number RepairClinic com
Jun 14, 2016 | Ovens Ovens
Oven lights come on, clock works, nothing else works won'heat up or anything
Check online for your oven and it might show different problems with that type. Also, my oven did that and it was just the heating element on the bottom. The top one was working okay. I looked on Amazon and found the right one by range model #. It only costs about 20.00 and easy to install. If that isn't the problem, it might be the wiring in the back. If that's the case I would call someone.
Dec 24, 2013 | Smeg SE210X/1 Stainless Steel Electric...
Hi smeg se210x/1 doesnt want to heat up to a decent temperature?
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
May 30, 2011 | Smeg SE210X/1 Stainless Steel Electric...
Hi Our oven wont turn on, has power as the display panel has a little "A" luminated on the left of display screen but nothing else operates, no fan, Grill, timer. please advise
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Mar 24, 2011 | Smeg SE210X/1 Stainless Steel Electric...
Morning I have a Stoves EFA600H electric oven and whilst the hob still works ok the clock and oven do not. The clock did start flashing last week and now has gone completely - any...
The electronic clock/timer must work correctly and be in manual mode for the oven to work. It sounds as if you need to replace the electronic clock. If you do not need the clock function it is fairly easy to bypass the clock altogether and the oven will work no problem.
Feb 23, 2011 | Stoves Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
I have an oven with digital clock. Every time power is cut, it seems that the digital clock needs to be repaired by replacing it. If the clock does not work, oven is not operative. Is there a way to solve...
Yes, it is simply matter of bypassing the clock/timer so that the oven thermostat will have permanent power going to it all the time. It is a matter of removing the active and load wire at the rear of the timer and joining them together.
Feb 11, 2011 | Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg SE210X/1 Stainless Steel Electric Single Oven Logo
99 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
