Question about Car Audio & Video
What are the color scamadics for a 2005 ford focus sterieo wire diogram i need to splice into it
    Problem Solver:
  • 5 Answers
It is highly recommended that you do not splice into your factory wiring harness. the best solution i can give that will save you time and money in the long run, is to go to walmart. back in the automotive section ther will be some radios and such, around that area is the proper connector for your focus. if you cant find them, feel free to as an associate
Posted on Aug 24, 2010
2002 FORD FOCUS NEW YAW RATE SENSOR WIREING DIOGRAM FOR 6 WIRE PIG TAIL
They gave you the wrong one. If it didn't come with a new plug to wire to the car. The one you got won't work. Even if you hard wire it.
Dec 30, 2015 | Ford Cars & Trucks
2005 Ford Focus is dead until I wiggle the battery wires
A ground wire that is not grounding, until you wiggle the wires. Follow those wires, there is a loose connection in there. Start at the neg. battery post, clean and tighten. Follow the small wires you can wiggle, see any splices that may have started to pull apart? Find the ground screw or whatever the small wires use to ground, that may be loose. Maybe the small wire goes to that black box? Take it off and look for the ground that isn't grounding.
Aug 16, 2013 | Ford Cars & Trucks
My 2005 ford focus CD player doesn't eject the disc out. what is the problem. second i got 2007 ford focus stereo but the connection harness is different how do i convect it to connect to my 2005 ford...
It is very common on Ford models of that year to have cd's not eject. If you are using burned cd's, these are generally to thick for the player to handle. Working at the Dealership i have seen this many times. As far as the wiring harness, its colors should be the same as the old one , so you need to cut off the connectors and reattach.
Sep 21, 2011 | 2005 Ford Focus
How to remove and alternator on a 2000 ford focus
autozone.com click the repair info tab and sign up. it has alot of how to's and step by step and diograms and recall info and so much more.
Mar 11, 2011 | 2000 Ford Focus
I have a 2005 ford f150 s/cab. the power windows,locks and mirrors won't work from the drivers door. the locks will work from the passanger door and by the remote, but winows don't work any where. the...
2 things.
1. Broken ground in the rubber channel from the door to the a-pillar. This is a black wire in that loom.
2. Bad splice in the driver's side door sill. Some of the manufacturing plants used a splicing tape ( not the VA plant ) that looks like hockey tape. You will need to pull the door sill to see if the 3 wire splice is bad. This is usually on the Standard cab and SuperCrew models, have not see a splice issue with the SuperCab configuration yet.
Start with pulling the switch panel, and check from the black wire in the loom to a ground lug behind the kick panel on the driver's side by the parking brake.
Jan 25, 2011 | 2005 Ford F-150
Front right headlamp connector has shortened out and melted. need to replace
Yes, that happens. A resistance casuses the spring tension to lessen, and the resistance goes up. Splice in a new connector, and a new headlight and you should be good to go.
Sep 16, 2010 | 2005 Ford Focus
What type of antifreeze is used with a 2005 Ford Focus
Hello mk12x.
Ford specification is Motorcraft Premium Engine Coolant VC-4-A (in Oregon VC-5, in Canada CXC-10) or equivalent meeting Ford specification ESE-M97B44-A (green color) with a mix of 50-50 coolant and clean water.
I hope your repair goes well for you.
Kl
Dec 17, 2009 | 2005 Ford Focus
Determine hot wire color and location w/ignition on
yellow. you can splice into your factory wiring and work the same as if your ran one straight from the battery
Jan 03, 2009 | 2005 Chevrolet Silverado
Wiring diagram for ford focus 2005 ghia 1.6
If you know which wires they are, ask an electrician to "but-splice" the wires back together.
Or if you think yourself wise enough to handle the situation, go buy, wire-strippers, **** splices and a crimper for those wire splices.
MAKE SURE YOU GET THE RIGHT SPLICES FOR THE GAUGE WIRE.
Strip the ends of either wire(you only need to strip about a1/4 inch), twist them CLOCKWISE, place them in the **** splice, and crimp the ends, and PRESTO! wire has continuity.
Make sure you splice the right wires together, or you will have blown fuses, and things not operating correctly.
Oct 07, 2008 | 2005 Ford Focus
Ford focus c max 2005 towbar wiring instructions needed
probably you have to open the tail light bulb and connect the wire there
Jun 27, 2008 | 2005 Ford Focus
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
