Question about Volkswagen Golf V Vw Scale Diecast Model
My windscreen wipers on my vw golf 2000 stop on the windscreen instead of the starting position.
Erratic windscreen wiper action
sounds like the wiper control itself is playing up
Feb 27, 2014 | 2001 Nissan Micra
Hi, I have a 2001 VW golf, and my windshield wipers won't work, they start to move slowly then they stop and they won't go back down? How do i fix this problem or what is the problem? i have check the...
How to check & change a wiper motor, and repair wiper mechanism on 2001 VW Golf
First time you must diagnose why windscreen wipers going slow and/or stopping.
In order to find out the cause of wipers stopping you can try follows:
1. Carefully extract the wiper arms from their axles (two pieces). In some cases you need to use an extracting tool. Heed of the windscreen !!!
2. Disassemble the plastic covers from the bottom of the windscreen.
3. With the bonnet up you can start the engine, (transmission in "N" or "P" position and parking brake on). Now you must switch on the control lever of the wipers, and go to the engine compartment. If the wiper motor runs let the wiper motor running for a few minutes and switch off. Go to the step 4. If the wiper motor do not runs you must check first the electrical feeding of the motor. If the electrical feeding is OK you must replace the motor - steps 5, 6. If not, you must check electrical connections, the control switch of wipers and harness.
4. Now you must check the two bearings of wiper mechanism with your hand. In the most cases the left bearing is out of order (is very hot). This is the most encounter fault of the wipers running.
5. You must disconnect the electrical coupling of the motor (difficult assurance), unscrew three bolts of the mechanism and extract together with the motor. You must move them slowly between windscreen and engine computer box until the wiper motor go out together with the mechanism. This is the most difficult operation!
6. Now you can repair the bearings, replace entire wiper mechanism or replace the wiper motor. It is not very simply, but it works.
Refit all in reverse order.
Feb 27, 2011 | 2001 Volkswagen Golf
Windscreen wipers only go half way
wipers stop halfway up windscreen
May 24, 2010 | 1999 Volkswagen Passat
1999 1.4cl auto VW Polo, windscreen wipers stopped working
Look into changing the ignition switch...sounds odd I know, but we had similar issue and that was the problem.
Feb 19, 2010 | 1999 Volkswagen Passat
Rear windscrenn wiper of Mk4 Golf not working
the linkage that work the wipers are probably gone
Jun 05, 2009 | 2000 Volkswagen Golf
VW Golf Windscreen Wiper
Sounds like the linkage part came off from the motor. You'll have to remove the 2 wipers arms and the plastic tray to inspect further.
Feb 15, 2009 | 2000 Volkswagen Golf
VW Bora wiper problem
Have you checked the wiper motor and linkages to make sure they are properly lubricated? Take care to keep your fingers clear of the (hopefully) moving parts! Your typical can of maintenance spray might get them going initially, but grease is really needed in the long run. D.
Jun 18, 2008 | 2000 Volkswagen Golf
Volkswagen Golf V Vw Scale Diecast Model Logo
47 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Bogdan Odwazny
Bogdan Odwazny
JonSnell Electronic
JonSnell Electronic
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
