Question about Refrigerators
Good day. I have refrigarator type of ERB 40402W,the problem consist of: doesn^t work automatic defrost system, on back side of cooling chamber so much ice. Temperature set point +5, temperature is keeping normally. At the changes set points the temperature kept correctly. Outdoor temp. +26. Give me please advise, what can i check in home condition?
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 24, 2010
The cooling in the fridge section stopped working. Freezing section ok. Left for defrosting for two days - restarted it - still the same. How to fix the cooling section/ ducts ?
Hard for me to find parts or pictures of that model refrigerator. You will just have to see why that vent is not regulating fresh food temperatures. Some vents open and close with a thermostat bulb mounted to the vent and some open and close electronically others are opened manually. Take a few photos and let me see what you are dealing with Contact Me Here APPLIANCE 911
Oct 06, 2015 | Electrolux Refrigerators
Side by side refrigerator will not cool on refrigerator side plus a build of ice temp control, model # psb2151grw
It sounds like your freezers' evaporator coils are not defrosting normally.At least once a day ,a refrigerator automatically defrosts the coils in the rear of the freezer compartment.In most cases ,the electric heater that is activated by a timer circuit,comes on and melts any ice buildup .If that heater doesn't come on for several days,the ice builds up into a solid block,and it doesnt allow any air to pass thru to the refrigerator side of you box.
Nov 14, 2012 | Maytag Refrigerators
Freezer side works fine, Refrigerator side is too warm
Hello.
The leading problem when freezer works yet the refrig. section doesn't get cold is going to a problem with a automatic defrost system defect. Do ya see a bunch of frost inside of the freezer on the back wall?? if yes ya do see that frost build up ist defiently not defrosting and this tip i wrote covers what to check when it doesn't defrost http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 04, 2011 | Jenn-Air JCD2389G Side by Side...
My jcd2389des freezer is working fine but the refrigerator isn't cooling properly
Hello Sharleen,
GENE
Oct 03, 2011 | Jenn-Air JCD2389G Side by Side...
This is for a kenmore top mount Refrigerator/Freezer Model Number 25363712302. Refrigerator was not cooling properly - was warm. Freezer was working, but after a couple of days, freezer also started to...
Since you say that is isn't cooling properly, I would first start off by cleaning the condenser grill that is located under the cabinet. While this won't correct your problem entirely, it will help!
Most likely you have a defrost system malfuntion. The defrost system consists of the defrost heater (p/n: 5303918208) which is the long tube like thing that sits directly below your evaporator behind the panel in the back of the freezer (inside the freezer). It also consists of the defrost thermostat (p/n: 5303918202), which is located next to the evaporator. Both the defrost heater and defrost thermostat can be checked with an ohm meter - a non-open/infinity reading is good. If both of those check out and are good then it has to be the defrost timer (p/n: 215846602) which is located behind the plastic shield (with the light bulb).
Suggest you defrost the unit (making sure no ice or frost is behind the freezer panel then plug the refrigerator back in. If everything cools down then my diagnosis is correct and one of the components of the defrost system is bad.
Oct 03, 2011 | Kenmore Top Freezer Refrigerator
The back wall of my hotpoint freezer/refrigarator is frosting up what is wrong whit it.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Doesnt cool freezes up, if unplugged and thawed out restart it works for several days then doesnt cool again
Good day,
the problem with the machine is the defrost system.
It is made up of the following parts.
1. behind the rear panel in the freezer section, is a defrost heater located at the bottom of the evaporator coil, that can burn out.
2. The defrost thermostat which is a round disc, located at the top of the evaporator coil. It can fail as well.
These first 2 items are pretty straight forward, and can
be replaced fairly easily, and can be tested with an ohm meter.
The second half of the defrost system, is electronic.
It consists of thermistors mounted in the freezer compartment which are there to determine when a defrost cycle should be initiated, and as well control the fan speed.
They send information to the mother board which is mounted on the rear of the machine behind a cover panel. This board controls all defrost activities, and is very pricey. $150.00 plus.
The main heater has had it's share of failures but is only one of the potential failures.
Unless you have a strong knowledge in electrical, my advice is to call a tech with knowledge of this machine to at least diagnose the problem, regardless who does the actual repair.
Nov 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
How do i know if the defrost timer is bad
Freedge keeps working and does not turn off and even it doesn't cool it self. and that makes us to understand that defrost timer is bad.
as it keep working and keep making ICE and as toimer does not work Heater will not work to defrost the ICE and it blocks your GAS chamber wich leads in to freedge keeps working but no cooling process and gas chamber is chocked up.
Oct 27, 2009 | Kenmore 57029 Side by Side Refrigerator
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Re: Refrigator will not stay cold
defrost problems are caused by 3 things
bad: 1) defrost timer/ timer board 2) defrost heater (in freezer) or burnt wire going to the heater 3) bi-metal thermostat (round metal piece attached to the coils with     at least 2 wires going to it)
a good technician can test components without the machine running. all you need is a simple $5 meter any tech that gets angry, show him/her the door!
Jun 15, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
