Question about Canon imageRUNNER 105 Copier
Having trouble with my IR105 getting Error code E000218-0000. Any Suggestions? Thanks
3 Suggested Answers
  • 86 Answers
SOURCE: IR8500 giving E000830-0000 Error code
i know what the problem is call 07764303923
Posted on Feb 14, 2008
Having trouble with my IR8500 getting Error code E000218-0000. Any Suggestions? Thanks
Posted on Apr 04, 2008
Ir105 canon model error code E000068-0000
Hi Mohammad.
There is an error in the high-voltage output to the separation charging assembly.
An error (leakage) to the high-voltage output to the separation charging assembly is detected.
Check if the transfer charging assembly and separation charging assembly are mounted properly. - Check if the connector (J722, J723, J730, J734) of the HV-DC PCB and the connector (J741, J742) of the HV-AC PCB are mounted properly. - Replace the HV-AC PCB. - Replace the separation charging assembly. - Replace the pre-transfer charging assembly. Canon iR105 Error Codes List page 3 from 9
Aug 15, 2016 | Canon Imagerunner Ir 105 Copier Printer...
105 model cannon error code E000068-0000
I've already answered this, please don't keep posting your question, it doesn't help us to help you. Canon iR105 Error Codes List page 3 from 9
Aug 15, 2016 | Canon Office Equipment & Supplies
Error code E000068-0000
This is the third posting of this question from you. Please don't do this in future. Canon iR105 Error Codes List page 3 from 9
Aug 15, 2016 | Office Equipment & Supplies
Canon 105 error code E 000220-0000
Here is the information I found online explaining the error code above:
http://www.copytechnet.com/forums/canon/5926-canon-ir105-error-e000222-0000-a.html
Jul 21, 2016 | Canon Office Equipment & Supplies
Hi every one.i have canon copier ir105 gives me error code e602-102. I replaced hard disk ,after that the machine gives me error code e000744-2000 please if any help thank you
maybe the dc controller is also need to replace or try to reset the error first to reset the error code press * 2&8 simultaniously,* then select copier, then select function, then select clear, then select error, then press ok & turn off & on the power switch
Nov 21, 2010 | Canon imageRUNNER 105 Copier
I found error in canon ir7105, and i checked
According to the code, the problem is in the laser unit. It sounds like I'm talking to a technician, so I'll approach the problem that way. I personally would first reseat all the electrical connectors on the main PCB as well as the laser unit. Loose connections do sometimes cause codes like this one. The other thing I'd do before tossing the laser unit is to reset the error code because again, codes like this one do come up when the AC power fluctuates from time to time. This is accomplished by entering service mode and then resetting the error . . . your service manual for the ir105 will give you the same method for service model access and the general sequence is the same for resetting the error. Good luck.
Dec 14, 2009 | Canon imageRUNNER C3200 Copier
I am having trouble trying to install Adobe Flash even after doing all of the usual suggestions. Any Help?
What kind of trouble are you having? Are you getting any error/missing file error messages? What version of Adobe are you using and/or are you trying to update Adobe when you are getting these error messages?
Jul 09, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Nov 30, 2007 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 105 Copier Logo
129 people viewed this question
old marine
old marine
