Question about Watches
Hi i have a radio controlled watch 3atm with a small digital display and 4 buttoms on it i cant st the time on it other wise its ok and i dont have a manual
    President:
  • 2,501 Answers
If the time is "incorrect" i.e. not your local time, then it is set to another time zone.
To correct this press the "mode" button until you come to a display showing three letters. These are city abbreviations and you may have to guess which one you need.
Some experimenting will be required, good luck!
Posted on Aug 24, 2010
  • cvandcp Aug 25, 2010
    I have a radio-controlled E687 R/F watch, with an instruction manual. This watch has only 3 buttons; but for what it`s worth, these are the instructions after replacing the battery:
    All hands, hour, minute, seconds, must be moved to the 12 o`clock position - Press and hold the top button to set the seconds hand fast running: stop the fast running by pressing the top button; restart it by pressing the top button again (!); when the fast-running seconds hand is driving the hour and minutes hand close to 11.59.00, give one press to the top button; continue to press that button one press at a time until all hands align at 12.00.00. Now press button 2 to confirm. Wait until the watch is running again before checking and setting your watch to the right time zone.
    I would never have managed that in a month of Sundays just by experimenting!
    Tom.
I dont know how to change the time on my decathlon geonaute watch
I nearly went crazy pushing buttons, but finally got the right combination. From the normal Time Display (as you would normally use the watch, no need to push any buttons) Push and Hold for a few seconds the Lap/Reset Button. The "Set" Mode will become active. Release the Lap/Reset button when Set appears in the Display. Notice in the Display a small Arrow that points to a button, either the ST/STP or Mode Button. (Initially it will be the ST/STP Button). When you depress the button to which the arrow points, the Field Flashing in the display will be set (For ST/STP) or Changed to the next Field (When the Arrow Points to the Mode Button). Simply toggle through the fields (using the Mode Button) and set (using the ST/STP Button) as needed. You will also be offered the ability to set the Month, Date, Day, 12/24 HR, and a M-D (It stands for Month - Date, in Europe it's more common to display as Date - Month). I did not change this field since by default on my watch it displayed M - D first. The setting cycle will be finished off when you have set the various fields by again pushing the Lap/Reset Button. Not related to setting the watch, but possibly useful, the Watch will completely reset if all the buttons are pushed at the same time, including pushing the Display Light (or in the case of this watch, the illumination used for the Display Characters). Hope this helps, it worked for me.
Nov 01, 2011 | Watches
Set time
Hi ajandmjm,
Please follow the steps below to set the time of your Armitron Digital Sport #40/8125BLK Watch.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Apr 26, 2011 | Armitron 40/8125BLK Digital Sport Watch
Set the time on a Armitron WR330 40/8125 All-Sport watch
Hi jerryurq51,
Please follow these steps to set the time of your Armitron Digital Sport #40/8125BLK Watch.
Hope it helps.
Apr 22, 2011 | Armitron 40/8125BLK Digital Sport Watch
Have a Aquasport 3ATM watch(red). Could
Was not able to find an actual manual for the Aqua Sport watches but what able to find a posting on How to Set an Aquatech Watch. Perhpas the following will be of assistance:
http://www.ehow.com/how_4587869_set-aquatech-watch.html
If this does not help, are you able to provide any more infmration about the manufacturer and the specific model you have.
Apr 16, 2011 | Watches
Bottom right button is light, not EI. top left is adj button left is mode top right is st/stp. I can't set time and date and can't turn off my alarm
hi..
El stands for
To set the time
  1. Press and hold [ Adj button ] till the digits on screen starts blink.
  2. Now Press [ Mode Button ] repetitively to cycle through Hour -> minute -> Seconds
  3. Press [ ST/STP button ] to adjust the value. Each press will increase the value.
  4. Press [ Adj Button ] again to save the changes
To set the alarm
  1. Press [ MODE Button] till it displays Alarm Time.
  2. Repeat steps 1 to step 4 as described in 'To set the time'
  3. Different watches have different procedures to active the alarm. Common method is pressing a button briefly.
    Since model of watch is not specified, Try pressing [Adj Button] or [ST/STP Button].
Mar 18, 2011 | Watches
I cant figure out how to set time and date
Hi idarr,
Please follow these steps to set the time and date of your Armitron Digital Sport #40/8125BLK Watch.
Hope it helps.
Mar 13, 2011 | Armitron 40/8125BLK Digital Sport Watch
Cant set the day and date on the Armitron 40/8106 watch - time is ok.
Hi madlugi,
You can easily change the day and date of your Armitron watch by following the steps below.
Hope it helps.
Dec 05, 2010 | Armitron 40/8125BLK Digital Sport Watch
I cant get the time set correctly! When i follow instructions it just seems to set the alarm! How do i do it?
Hi jeffrey_lafi,
You can easily change the time and date of your Armitron watch by following the steps below.
Hope it helps.
Jul 08, 2010 | Armitron 40/8125BLK Digital Sport Watch
Radio controlled 3ATM watch. I need instruction manual. Cannot reset time or synchronise.
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please.
Mar 31, 2010 | Watches
How to set armitron digital watch 45/6915?
Assume A B
C D
To turn off the alarm press & hold A then press B, do this several times until your alarm/chime is either on or off.
Jul 18, 2008 | Armitron Watches
Watches Logo
286 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
