Question about GE GSS23SGSSS Stainless Steel Side by Side Refrigerator
Has stop cooling, but work eariler. Interior lights are on but the comp.. will not cut on.
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 24, 2010
LG Express Cool Turbo GR T542G Stopped cooling
it should run when the comp is on and the unit is calling for cooling, you most likely need a new fan for your unit.
Aug 10, 2013 | Refrigerators
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
2002 Subaru A/C works intermittently
make sure condensor in front of radiator is free of debris this can cause cooling problems also mak e sure engine is not overheating this will shut a/c down also
Aug 14, 2009 | 2003 Subaru Forester
I have a Ford F-250, the air conditioning works for about 15 minutes when you turn it on and then it cuts out and blows out warm air. Is this a relay problem?
Yes,
The cooling fan for the condensor or radiator is not coming on. The system is getting to hot because of this and building pressure. Then cuts off.
I would have the a.c system check for leaks and recharged. Then check the cooling fan and relay.
Very common problem.
Jul 16, 2009 | 2003 Ford F250 Super Duty Crew Cab
2002 Impala AC will not work unless interior lights are on
you have a bad ground and it's the door switch wire most likely on the kcik pannel on passenger side.
Jun 19, 2009 | 2002 Chevrolet Impala
Instrument panel and interior lighting not operating, 2004 F150
sounds likke u got grounding problem with ur wiring. if ur fuse pops wen u install a new fuse. this means ur grounding wire is cut or touching with metal. if doesnt pop,then it is ur power wire that is cut or touching the metal (grounding out)
Jan 12, 2009 | 2004 Ford F150
The appliance interior lights works but it's not cooling or freezing
The compresser could fail yes, but you could also have an open circuit. If the contacts in the thermostat got corroded, or the starter relay, it may simply not be told to turn on. It may be time for a technician to measure continuity in the circuit.
Jan 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
GE GSS23SGSSS Stainless Steel Side by Side Refrigerator Logo
14 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
