Question about Xerox Phaser 7300DN Laser Printer
Xerox phaser 6303 printer shows "replace transfer unit" what does it mean,.
  • 87 Answers
The transfer unit is the part of the printer which transfers the image created by the imaging drums onto the paper. After a certain amount of use it has to be replaced to maintain print quality. At that time, the printer is programmed to show the message you have received.
Posted on Mar 26, 2011
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Phaser 6505 imaging unit life reset
HELP.. replace transfer unit... I replaced it.. still a
replace transfer unit message.. help!!
Nov 27, 2013 | Xerox Phaser 6128MFP AllInOne Laser...
OUR PHASER 6180 PRINTER IS SHOWING FUSER LIFE AND TRANSFER LIFE NEEDS REPACING SOON. WHAT ARE THEY AND WILL IT COST MORE TO REPLACE THAN BUY A NEW ONE
Go to this WEB site for fuser parts.
http://www.sparepartswarehouse.com/Xerox,Phaser,6180,6180N,Printer,Fusers.aspx
Go to this WEB site for transfer belt part.
http://www.fastprinters.com/ProductDetails.asp?PARTNO=XER-675K47088
May 16, 2011 | Xerox Phaser 6180N Laser Printer
We can find any information for the transfer roller for the Phaser 6180, 6280 keeps coming up. Is our machine obsolete?
No, your machine is not obsolete. You're probably not finding anything on the transfer roller because it is really part of the transfer unit (part# 675K47088 ) The transfer unit contains the transfer belt and roller. Here is a video that shows you how to replace it.
Apr 28, 2011 | Xerox Phaser 6180N Laser Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 7300 color misregistration
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser - Transfer Unit issue
Hold down Back and Information and turn on the printer. You enter in service mode. Then you can reset CRU counters.
Jun 19, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 7400
There really isnt an easy way to do that.
The transfer belt assembly starts off with a fuse on it to blow immediatly on install, and a counter that is internal so that it will end of life and have to be replaced. It's really not a convience counter but an obsolence counter.
Mar 06, 2008 | Xerox Phaser 7750B Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
