Question about HP iPAQ H4355 Pocket PC
Dead batter So I let my battery go dead. plugged it into the usb sync cable (that also charges the unit) and nothing is charging. What do you do with that?
  • Anonymous Feb 26, 2009
    I've had the Ipaq for four years and now it's not charging at all. I can charge the battery in the docking cradle but once I put the battery in or place the iPaq in the dock, nothing will power on at all. Could it be the backup battery? I thought the unit would at least power on like a hard reset, but I am getting nothing at all.
  • 409 Answers
If it is very flat it can take quite a while to appear to be doing anything.  Try using and external charger and resetting it after 15 mins on charge
Posted on Oct 30, 2008
I have an ipod model a1199. i was wondering if you can use a newer ipod touch charger for it? and if not what kind of charger does it use?
Charge an iPod Nano Without a Charger
If you've misplaced or broken the charger that came with your iPod Nano, you might think you need to purchase a new one in order to continue using your Mp3 player.
However, there is a way that you can continue enjoying your iPod without having to purchase a new charger.
As long as you have a USB cord and a computer, you can charge your iPod without having the charger.
Locate the USB cord that came with your iPod Nano package.
It is the same cord that you use in order to sync or transfer music.
Plug the small end into your iPod Nano.
Plug the other, larger end into your computer's USB port.
Choose "Do Nothing" when your computer presents the dialogue box to let you choose what to do with the hardware or USB connection.
Leave your Nano plugged into your computer for at least 4 hours to charge.
Unplug your iPod Nano when charging is complete.
Charge an iPod Without the Charger
Many iPod owners purchase a charging unit that plugs into a standard wall outlet to recharge the iPod's battery.
However, the iPod wall charger is not included with new purchases, so consumers must either purchase a separate charger or find a way to charge their iPod using other means.
Here's a simple method to charge your iPod using your computer.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by clicking on the icon in the Dock on a Mac or using the Start menu on a PC.
Click on the name of your iPod under the "Devices" heading in the main iTunes window.
Click on the "Sync" button to synchronize your iPod with your computer data.
While the iPod is syncing, the power from the USB port on your computer will charge your iPod's battery.
Unplug your iPod from the computer once the battery is fully charged. - view=detail&id=8DEA58C0DAF392E29FCB03D9C
This one should be ok.
Aug 05, 2013 | Apple A1199 ipod nano
My john deere la125 seems to be drawing power wile shut down, it take a week for the batter to go dead, i've pulled the batterer and it stays charged up , I've checked the charging unit and i
What you do is power off the machine, and disconnect the negative battery cable. Put a test light or volt meter between the battery negative terminal and the disconnected negative battery cable.
You will likely have a light or voltage reading...Then you start disconnecting things....I suggest the alternator.
When you have the correct component disconnected and the test light or volt meter shows no current.
If this component is the alternator, they have diode sets inside (or somewhere else in the charging circuit) Typically one diode fails and this causes the draw that you describe. The system often still charges, but at a slightly lower capacity with the failed diode.
Nov 23, 2012 | Garden
I have the powershot SD3500IS abd it says i need to change the battery pack what is that and how can i fix it also if i dont have a charer can i charge it with the usb ?
"Change batter pack" means your battery is dead. The camera should have come with a charger in the bok that can plug into the outlet in your wall. It uses a lithium ion battery, so you can't use a regular AA batter charger, for instance. You cannot charge the battery via the usb into your computer.
Nov 06, 2010 | Canon PowerShot SD3500 IS / IXUS 210...
plug it in to your computer via the usb cable for a few hours, the car and home chargers are not recommended for the initial charge as there only a trickle charge...if it still hasn't charged up using the usb cable, there is probably a problem with the usb port(charging port)
let me know how you make out after charging it via the usb cable that was supplied with the unit.
Aug 20, 2010 | Tomtom ONE GPS Receiver
Garmin nuvi unit was indicatig battery charging when i . conneted to my computer. I removed and tried to turn this on did not and then I have re-connected to my computer again and even tried to...
It take a day to charge the 260 WITH the correct cable for your computer as it will only trickle charge it.
Car charge does it in 2 - 3 hrs. If car is not charging it check the fuse in the end of the charger
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F
Jan 04, 2009 | Garmin nuvi 260W GPS Receiver
Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
have you only been charging it with the usb cable?
try plugging it into a ac adaptor, (make sure the button is in the off position at the bottom)
and it should hopefully restart, then turn it to the on when it's loaded, and leave it plugged in till it's completely charged
that might work
Feb 26, 2008 | Toshiba gigabeat S MP3 Player
My charging port seems to not work
My advise to you is if you have Sandisk Sansa m240 it does not come with a chargeable battery so you cannot charge it,replace it and your problem will go away. I replaced my unit with a rechargeable battery and I have no more battery problems. I charge my batter in a charger when needed.
Nov 20, 2007 | SanDisk Sansa m240 MP3 Player
I called and they told me,i have the same problem, to just turn the battery switch ( bottom thing) off and charge it over night via wall outlet. hope it helps im trying it as i type so i wouldn't know...
Jul 29, 2007 | Toshiba gigabeat S MP3 Player
Audiovox SMT 5600 will not charge
If your battery goes COMPLETELY dead, which it will do if phone is not turned OFF and not used for a long period of time, you will need to JUMP START it using you OEM SMT-5600 AC charger. Other AC chargers will not work for this purpose and neither will a USB port.
You can JUMP START the battery using a USB port by cutting off a USB cable to expost the red and black power USB PORT power pins 1 and 4. Remove your SMT-5600 battery and while the modified USB cable is plugged into your USB PORT, hold the BLACK wire to the negative (-) terminal and the RED wire to the positive (+) terminal for about a minute. Replace the battery in the phone and connect the phone to a USB PORT using a standard USB cable. The SMT-5600 charging light may not register for a while, but will eventually light amber to show it is charging, assuming your phone is recoginzed by your computer.
Note some mini USB cables DONOT carry the USB power leads through to the phone, only data. If you have a very thin USB cable, be suspicious the power leads are not being carried in the cable.
Since the USB PORT power is limited to 100ma it cannot hurt the battery, but will insert enough current into a totally flat batter to cause the battery to register a voltage large enough to alllow USB PORT charging, typically 3.7VDC.
Nov 18, 2006 | Audiovox SMT5600
USB Sync Cable
I dont' think so. No other PDA does - it would be quite a drain on the USB port. It isn't like powering the tiny LED in an optical mouse.
Sep 13, 2005 | Dell Axim X5 Pocket PC
HP iPAQ H4355 Pocket PC Logo
95 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
