Question about Bose 3 2 1 GSX System
Dvd playback, picture is poor, there is a honeycomb effect over the whole screen, dark colours show this up worse, but its all over. I dont think its the tv as its fine on digital tv.
  • 4,234 Answers
This is a video processing problem not related to NTSC vs PAL. This is a rare problem that is not likely to be resolved here. If the DVD player was an inexpensive one, just replace it. The only way to repair is to replace the processing board which will probably cost almost as much as a replacement unit.
Dan
Posted on Aug 24, 2010
  • 75 Answers
Check ntsc and pal setting on the player.if tv is on ntsc then the player should also be on ntsc.
With some dvds picture is split screen showing the picture on both halves of tv screen, how do I make this a single picture on whole screen?
HI,
Check on thing Go to the SETUP Menu and check is there is any System settings (colour system) on both DVD and TV . Try all the settings available in the colour system setting. As you didn't mentioned anything about Brand and model number of the player or tv. Its not possible to give you the exact solution.
Ajin
Jul 25, 2012 | Audio Players & Recorders
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
Plasma tv problems
Thanks for the photos, it looks like an internal adjustment is required to the ramp generator which controls the sequence for the screen to refresh itself from a previous image to a new image. This is a precise setting & also a software update may be necessary to cure the problem. These settings are on the Y-Sutain board & need to be accurate.If this procedure does not cure the problem then the screen will need replacing. As it will out of warranty, it would be best to contact a local repair centre & ask for an estimate to try & set these adjustments for you.
Sep 23, 2009 | Televison & Video
Printed photographs have a square tiled effect
please you change your color cartridge and buy new one then solve your problem
Jul 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Blured pictures and false colours
I would slap the camera face down in my hand as hard as I could.
May 12, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
I have a DVD v6000. The DVD playback is fine but with the VCR the colour is fragmentary and unstable. I have tried cleaning the heads to no effect.
How did you clean the heads? Cleaning tapes cannot do as good a job as a manual cleaning.
Another possibility is a failing power supply. Is the problem worse on tapes you record than prerecorded tapes?
Usually if it the power supply the sound will have a slight warble.
Aug 18, 2008 | Samsung Televison & Video
Casio exilim EX-Z75 BLACK COLOUR - UK/EUROPE
Go into the menu screen. There is a "reset" option.
Dec 18, 2007 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Picture is green and fuzzy in shaded areas
I have only see this issue caused by either a defective main bd. or a defective A/V bd. I am sorry but both would require a new bd and no simple repair exists.
Jun 18, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Bose 3 2 1 GSX System Logo
193 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
