How do I paint an image for iron-on transfer with the image reverse i.e. mirror image? On a Pisma 6600D
  • 2,039 Answers
In the Printing Options/Printing Preferences box, Main tab, select T-Shirt Transfers as Media Type.
Posted on May 05, 2008
Mirror image
To reverse an image for iron-on transfers
1. On the File menu in your software application, click Print.
2. Make sure the product is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Features tab.
5. In the Paper Type drop-down list, click More, and then select HP Iron-on Transfer
from the list.
6. If the selected size is not what you want, click an appropriate size in the Size list.
7. Click the Advanced tab.
8. In the Features area, select the Mirror Image check box.
9. Click OK, and then click Print or OK in the Print dialog box.
Read More.....HP Printer Support
Thanks,
Aug 05, 2014 | HP Business InkJet 2800 Printer
Printing mirror image
Check for the printer settings, if it has mirror image feature. Other wise, or try once below settings:
from the list.
You can avail our technical services by visiting our website; http://www.vtechsquad.com.
Apr 25, 2013 | Casio Canon PIXMA MP480 USB 2.0 All-in-One...
How to mirror image for t-shirts?
To mirror an image, you can import into a program like Microsoft Word and then flip it horizontally.
Feb 28, 2011 | HP C4795 AllInOne InkJet Printer
Using a C3100 series HP inkjet printer, I'm trying to print HP Iron-on Transfer Paper but when I select that option, I cannot get the appropriate reverse image need for ironing on the transfer. What's...
The steps vary by printer. I've got a c7280 installed and the options for me are to click Print > Preferences > Advanced > Mirror image. When you click on Mirror image, you change it from 'off' to 'on'. Click OK to save the setting and print. Be sure to change it back after you're done printing your transfers.
I am an HP employee. I do not represent HP on this site.
Sep 14, 2010 | HP Photosmart C3180 All-In-One InkJet...
Where is my mirror image feature?
Looking at the User Guide, it appears that the Mirror Image option may require you to select "Iron-on transfer" as the paper type (see p. 96 in chapter 7):
1.
2. Make sure the HP All-in-One is the selected printer.
from the list.
8. In the Printer Features area, select On from the Mirror Image drop-down list.
Jun 25, 2010 | HP Photosmart C7280 Laser Printer
How print iron on transfers
Yes, you need to "MIRROR" the image. Go to printer properties and select the ADVANCED TAB. Click on the MIRROR setting then print onto the transfer paper. The image should print out backwards like you are looking at it in a mirror. When you iron it onto a shirt, it will come out correct.
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
I WANT TO PRINT MIRROR IMAGE ONTO MEDIA FOR A T-SHIRT
Hi I am Vortash if you want a mirror image of anything you print all you have to do is reverse it in the picture or the writings you are printing .. most good graphic/ paint programs will allow you to do this Paint shop pro to name but just one and Coral ?
So If you want the picture on your t-shirt the right way round after transfer just select mirror image before you start your print run .. Regards Vortash
May 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
How do I select mirror image (reverse image) from HP Photsmart
When you select Print and the Print window opens, select Preferences.
Click on the Advanced tab. Look for the "Mirror Image" option. It should be "Off". If you click on "Off" the drop down menu should appear to change it to "On". Click "OK" at the bottom. Then click "Print" on the Print window.
Don't forget to change it back when you are done. :-)
(Note: If the Mirror Image option is not on the Advanced tab, look on the Effects tab.)
Apr 22, 2009 | HP Photosmart C7280 Laser Printer
Setting up printer for reverse/mirror printing
I used to use iron on transfers all the time for different things. The setting is usually available whan you attempt to print the image you have different options in properties. Under the advanced tab in printer properties there is something called media type. You can set this to iron on transfer. To locate printer properties in XP for example go to Start>Control Panel>printers>view all printers right click on the printer you intend to use and select properties.
Mar 12, 2009 | Canon Office Equipment & Supplies
156 people viewed this question
jasbo
jasbo
