I want to connect internet on my psp through a wireless access point but iam constantly recieving dns errors , what settings should be made on my psp and my access point? to solve the problem???
  • 75 Answers
  1. Connect your router
  2. Open a brower window on your computer, preferably Internet explorer.
  3. Enter the IP address of the router (Ex: 192.168.1.1)
  4. Upon entering the IP address of the router in the browser it should direct you to your router box. If this does not happen then most likely your router box has been configured to a different IP address. To get this IP number run the set-up program.
  5. Now in the routher settings navigate within your router's settings dialog and locate "Wirless Settings"
  6. Check if you are assigned a SSID
  7. Check your region
  8. You should be on Channel 11. Sometimes the channel could different, in such situations make sure you are on the same channel.
  9. Check if "Allow Broadcast of Name (SSID)" is enabled
  10. Check if "Enable Wireless access point" is enabled
  11. Set authentication as "Open system". You will find this option under "Security Encryption (WEP)"
  12. Set strength of encryption as "Disabled"
  13. Now click on "Wireless Card Access List". You may need to provide your password again.
  14. Make sure "Turn on Access control" option is turned off "Disabled"
  15. You should now see your PSP listed. No, you dont see then on your psp, go to "system settings" and then to "system information". You will see MAC address, now make a note of this MAC address.
  16. Now in "Wireless Card Access List" select "Add". If you are not able to do this then enter the PSP's MAC address and click "Finish/Apply" when done.
  17. In WAN settings, verify that "Connect Automatically as required" is enabled
  18. In "LAN TCP/IP Settings" make note of all of the information included. You may need this later. You may not, but it's a good idea to take note of it now.
  19. Under "Router Status" make note of all the relevant information included here as well. You may or may not need it.
or click to view manuals.playstation.net
Posted on Aug 24, 2010
    Sergeant:
  • 203 Answers
Try putting Access Point into WEP mode and give the new password to your PSP. Also if your Access Point is hidden from broadcasting it's name, it wont be found so make sure to manually type in the Access Point name on your PSP.
When I try to connect to the internet using a wireless connection, a screen comes up says "Communication with the server failed. A DNS error has occurred. (80410402)." How do I fix this problem?
if it is saying DNS error it is not a problem with the PSP, most likely a setting with your wireless router. or a problem with teh internet at the time of trying. check wireless settings on the PSP and make sure it has a number listed for DNS server.
Nov 24, 2009 | Sony PlayStation Portable (PSP) Console
HOW DO I GET WIRELESS INTERNET ON MY PSP
You need to find out your router name or SSID first. Check the network setting in your router.
1. Go to Network Settings under the PSP settings menu.
2. Select the "Infrastructure Mode" and press X.
3. Under "Select a connection to edit", choose "New Connection" and press X.
4. Now you will enter the connection name, press X.
5. Using the D-pad, name the connection "<whatever your router name is>" then select Enter and press X.
6. Now the connection is named "<your router name>". Select it and press >.
7. Under WLAN Settings, choose to "Enter Manually" and press >.
8. The SSID screen will come up next. Select the empty space underneath "SSID" and press X.
9. Using the D-pad, type in "<your router name>" then select Enter and press X.
10. Under WLAN Security Setting select "None" and press >.
11. Under Address Setting select "Custom" and press >.
12. Next, set the IP Address Setting to "Automatic" and press >.
13. The DNS Setting should also be set to "Automatic". After this is done press >.
14. Under Proxy Server, choose "Do Not Use" and press >.
15. Under Internet Browser, select "Start" so that the browser will be started after connection to the access point. Press >.
16. This screen will show your Settings List, press the > button after looking over the list.
17. You are now done setting up your connection, press the X button to save your settings.
Test Your Wireless Connection
18. Once your save has been completed, select "Test Connection" and press X.
19. Your PSP will now test your connection by connecting to the access point, obtaining an IP address and starting your internet browser.
20. If all settings are correct, you should see a screen confirming the connection.
Nov 02, 2009 | Sony PlayStation Portable (PSP) Console
WHAT IS DNS ERROR ANDHOW DO I FIX IT
DNS error is already an issue with the Access Point you are connecting with.
If you are using your own access point, try to restart it. If the same still occurs, hardcode the DNS of your provider on the wireless router you are using.
Hope this helps.
Aug 12, 2009 | Sony PlayStation Portable (PSP) Console
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
Dns eror
you must know the dns address of your access point or wireless router you must creat new connection to psp scan and manual edit the primary dns and the dns address of your access point or your wireless router
Nov 13, 2008 | Sony Limited Edition PSP Daxter...
DNS error (80410411) cannot find server
If you are using a public router (meaning you're using just a connection from somebody else's router) prolly, you're DNS have been blocked...have you tried connecting to other sources other than the one you can't use? If you have a connection and you don't own your own wireless router, try borrowing one from someone you know first then try if it works...then that's the time you should ask for your own wireless router...
Jul 29, 2008 | Sony PlayStation Portable (PSP) Console
How can i put internet in my psp?
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
  8. Select a connection and press icn_btnx_color.gif.
  9. The web page will be displayed.
  10. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Highlight icn_settings.gif(Settings) from the home menu.
  3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
  4. Select Infrastructure Mode and press icn_btnx_color.gif.
  5. Select New Connection and press icn_btnx_color.gif.
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  9. Confirm the SSID and press the right directional button.
  10. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  11. After entering the security information, press the right arrow button to continue.
  12. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
  13. After selecting the address setting method, press the right arrow button to continue.
  14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  15. To save the new connection, press icn_btnx_color.gif.
  16. To test the connection, select Test Connection and press icn_btnx_color.gif.
  17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
for more information.
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
DNS error while connecting my psp
i got solution
dont solved problem!
ok solution:
click inafacture mode in network settings.
new connection > scan > now look for internet wchich has no security > choose it > then click left arrow > then choose easy and go to the save settings, save,test connection. IT WILL SAY YOUR INFO AT THE END AND THEN YOU CLICK CIRCLE GO TO INTERNET BROWSER AND ENJOY
IF SOMETHING GOES WRONG TRY AGAIN IN DIFFERENT PLACES.
it should work.
enjoy internet
Jan 13, 2008 | Sony PlayStation Portable (PSP) Console
Psp error
Connection PSP to internet
http://www.askdavetaylor.com/connect_to_the_internet_with_my_sony_psp.html
Jan 12, 2008 | Sony PlayStation Portable (PSP) Console
Internet connection error
Simple steps: 1. Push "up" the WLAN switch by the left side on your PSP 2. Go to "Internet Browser" 3. Go to "Address" 4 Type in your web address and pres "start" 5 When prompted with internet connection settings, choose new connection and Scan for Wireless access points. 7 Choose connection with no security and good signal strength, save your settings (Press "=>" all the way). 8. Select your newly made connection and there you go!
Aug 18, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
