Question about Saniflo & Saniplus& Macerator Pump
Im getting a constan grinding noise from the white box behind the toilet, still works, but very slow! how can i clear any blockage?
  • 46 Answers
Most likly you need to replace gasget its very easy to do you can get what you need from a hardware store or it could be your fill vaul its easer to replace the box will tell you how to do it just remember to turn off vaul at the bottum back of commode
Posted on Aug 24, 2010
What is causing my toilet cistern to fill very slow?
The fill valve (operated by the float) may be clogged with sand or debris from inside the pipe. It's generally easier to replace a fill valve than it is to take it apart & clean it.
Jul 31, 2014 | Caroma 270W-RF Reflection Round Front...
Toilet not filling fully and smell of sewer
This is usually caused by a partial blockage inside the toilet. Try using a plunger to clear it, if that doesn't work, get a toilet auger from your local home improvement store
Jan 28, 2014 | Kohler Cimarron 2-PC Elongated Toilet with...
Hiace loud induction noise
make sure there is no blockage or replace air fiter or maybe box not clamp together properly hope this helps
Apr 10, 2013 | Toyota HiAce Cars & Trucks
Sanipump toilet had a wipe put down it. i have taken the unit off the back and opened it but it wasn't blocked - put hand in and had good feel around! still making awful grinding noise when flushed. any...
it may have something stuck in the blade (on top of motor) or the impeller (at bottom of motor) to get to the impeller the motor complete will have to be removed out of the pump casing. Also check the discharge pipe for any obstructions. Also there is a pump cover plate located at the bottom of the motor and it will cause the unit to make a loud grinding noise if anything is stuck in there.
Dec 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Pump murmers now excessivley noisy
The best thing would be to just replace the whole pump... once they start giving trouble you will always have trouble...
the noise is either something bent or the motor has a bad spot in the windings...
heatman101
May 03, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
The toilet does'nt have the same flush pull taking a couple of flushes very slow draining
Check the following: Is the water level in the tank properly set? Is the flapper valve opening fully when flushed? And is there any blockage in the waste line? Use a plunger to try and clear the line if the first two items are OK.
Apr 24, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
How can you tell if the waste pipe is blocked on a saniflow toile
Yes the bowl will be slow to empty. Try squeezing the white discharge hose as the unit operates, if there is a blockage then this hose will be hard to squeeze. If hose is soft then blockage could be in the toilet pan U-bend in which case fill bowl with very hot water and leave to soften the toilet paper.
Jan 11, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo & Saniplus& Macerator Pump  Logo
103 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
