Question about Village 2X Black Alloy Chain Tugs 14mm Axle BMX Bike Tensioners
Write the place value of the underlined number 46
    President:
  • 2,047 Answers
Number $^is the number
Posted on Aug 24, 2010
Corel Draw 8 - Can you the color of the underline below the text be changed, a different color than the text?
right click for the any color u need change the underline color and F12 for line thickness (punch F12 and open new dialog box select 1, 2 what ever u want give thickness value then click ok or enter )
Jan 28, 2013 | Corel Draw 8
How to underline the text
which program ?
Underline Text in HTML b> Find or enter the text you want to underline. Place the text within a SPAN element, by adding an opening tag before the text and closing tag after. Specify underlining of the text within the SPAN by adding a STYLE attribute to it as follows:
STYLE="text-decoration; underline; " Add a CLASS attribute to the SPAN, giving the name of a CSS class which defines text underlining. This is an alternative to using the STYLE attribute as described in the preceding step. The format of the CSS class declaration is as follows:
.my-underlined-class { text-decoration: underline; } b> Underline Text Using HTML b> Find or enter the text you want to underline. Enclose the text within a U element, by placing an opening and closing tag before and after the text.
Underline Text in PowerPoint
PowerPoint includes shortcuts for adding font effects, such as strike-through, italics or subscript, to any text in your presentation. Like other products in the Microsoft Office Suite, PowerPoint also allows you to underline important words or phrases on a slide to help empha important aspects of your presentation. Microsoft's use of hot-keys makes it possible to underline text identically in all versions of PowerPoint.
View the slide that has the text you want to underline. Highlight the text you want to underline. Press "Ctrl" and "U" simultaneously to underline the highlighted text.
Underline Text In Word 2007
b> Microsoft Word 2007 makes it possible to create and edit documents for email or printed use. This word processing application allows you to add a number of formatting options that enhance your document. One of many features included in Word 2007 is the ability to underline words or sentences. You can make certain words stand out using either basic or decorative lines.
Open your Microsoft Word document and highlight the word or sentence you want to underline. Click the "Underline" icon located on the Home tab to underline the text. Select the text you want to underline, if you want to underline words, but not the spaces between them. Click the "Font" button on the "Home" tab and click the "Font" tab. Click "Words only" in the "Underline style" box. Select the text or sentence you want to underline, if you want to double underline. Click the "Home" tab and click "Font." Click the "Font" tab. Select "Double Underline" in the "Underline style" box. Select the text you want to underline, if you want to add a decorative underline. Click the "Home" tab and click "Font." Click the "Font" tab. Select the decorative underline you want to use in the " Underline style" box. Click "Underline color" and select the color you want to use for your decorative line. Click "Paragraph group" on the "Home" tab if you want to underline spaces. Click "Show/Hide" and press the "TAB" key. Select the tab characters that you want to underline. The tab character looks like an arrow. Press "CTRL," and "U" together for a basic line. Click "Font" on the "Home" tab if you want to add a decorative line to the space. Click "Underline style" and select the style you want to use. Hope this helps.
Jan 02, 2013 | Computers & Internet
Explain "CUT", "UP", "5/4"
CUT: Values are cut off to the number of decimal places speicified by the current Decimal Place Selector setting
UP: Values are rounded up to the number of decimal places speicified by the current Decimal Place Selector setting
5/4: Values are rounded off (0,1,2,3,4 are cut off; 5,6,7,8,9 are rounded up) to the number of decimal places speicified by the current Decimal Place Selector setting
May 04, 2011 | Corporate Express CEB95005 Calculator
Samsung HLP4663W I have changed Bulb, Ballast, and Color Wheel, Yes, removed the Jumper and set to CW2 too!(color wheel had no sticker with CCA Values or Actuator or Index Delay Values on it) I set the...
th dmd pcb can somtimes cost as much as a rebuilt light engine that comes with the dmd pcb colorwheel and dlp chip. look into a rebuilt light engine from tri state modules or pts electronics.
Feb 06, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Can't figure out how to underline
Although the the serial number is underlined on the sticker, you do not need to underline it when typing it in on the screen. If it needs to be underlined, it will be fix by the software itself by default.
May 11, 2009 | Toshiba Satellite A60 Notebook
Blown resister #46 need resistance value or color bands
From what if read number r46 is 150ohm im looking for the value of r45 hope it helps
Apr 22, 2009 | Yamaha YST-SW015 Subwoofer
What is the value of 3 in 53
in any decimal number each of the digits has two values
  • face value
  • place value
in 53 the face value as well as place value for 3 are 3
Thanks
Zulfikar ali
ali_zulfikar@yahoo.com
9899780221
Jan 30, 2009 | SoftMath Algebrator - Algebra Homework...
Tasco Manual
Hi - You can download the manual by clicking the link underlined in blue below:
46-114500
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 07, 2008 | Tasco Galaxsee 46114500 (500 x 114mm)...
Village 2X Black Alloy Chain Tugs 14mm Axle BMX Bike Tensioners Logo
19 people viewed this question
Top Village Cycling Experts
John Egan
John Egan
Are you a Village Cycling Expert? Answer questions, earn points and help others
