Desktop will shutdown as Windows XP screen comes up. Shuts down while trying to load into all safe modes. The computer is a custom built computer, and I have cleaned the inside of dust, and tried to change BIOS settings to not turn the computer off until the CPU gets to a certain temperature. The BIOS is stating the CPU is at 40 degrees Celsius, which the automatic shut off starts at 70 degrees Celsius. Even when trying to reload Windows the computer will copy all of the files onto the hard drive, but turns off once the Windows XP screen comes up. It sounds like there is a click when the computer turns itself off.
  • 119 Answers
I would start out by getting a power supply tester (which can be picked up fairly cheaply on Ebay) and checking out your power supply. If it is anything deeper than that, I would look into having a TECH look at it since it could possibly be a ground in the motherboard. You may also want to check and make sure that any expansion cards (memory, video) are seated correctly. If you don't have any expansion cards, it may be your onboard video going bad.
Posted on Aug 25, 2010
Testimonial: "Thank you for the response."
Used dell desktop windows xp pro. Have no username or password. Have burned a ubuntu cd but get no screen for It. Pic is bios screen that comes up. HELP?
Just move the cursor to safe mode then press enter. The PC will then load up everything one thing at a time. If you end up fully loaded you can then, shut it down and start it normally. The computer will tell you of any problems, during safe mode start up.
Mar 27, 2017 | Dell Computers & Internet
Last windows update now I can't boot it up. Window screen comes up and then shuts the computer down and statr all over again
Ensure NO media is plugged in first ie CD / mem stick.
May not be the Windows update. try booting into safe mode using F8 key, if you can access windows that way then problem is a program thats trying to load. To stop programs from loading go to safe mode
If windows wont load in safe mode then registry is corrupted.
Jan 26, 2010 | Toshiba Satellite A85-S107 Notebook
I have yellow vertical lines on my screen and when I try to update my video drivers the computer shuts off?
could be a bad video card. you could try resetting to default vga mode in windows.
just before booting into windows press F8 a couple times to go into safe mode.
when the safe mode list comes up, select VGA mode.
if you still have the lines, it probably a bad card or bad chip if it's built in.
you could add a new graphics card.
Oct 09, 2009 | Dell Inspiron 530s Desktop Computer
Shutdown
Try booting in safe mode (press F8 right at the end of the bios boot screen and select safe mode). If the problem still persists while running in safe mode then you probably have a hardware problem. In this case power down and re-check all of your connections, reseat any add-on cards, check all power cables, etc. If the problem goes away while in safe mode, then your problem is software related. In that case (while in safe mode still) try removing software and/or hardware drivers and rebooting normally to see if the problem goes away.
A fresh re-install of XP is always a good cure on these type of systems as well.
Jul 08, 2009 | HP Compaq d530 SFF PC Desktop
Tecra m1won't boot up properly.
1. Switch on your computer and press F8
2. you will find some options on the screen... such as SAFE MODE and many options which is related
to windows boot up.
3. select safe mode
4. Now you will be entering into windows XP in safe mode
5. uninstall the last software which you have installed, may be with some installation your computer
trapped in trouble..
6. restart your computer
7. if the problem doesn't cleared, then again goto safe mode which you have done in step 1,2,3,4 and
take backup if you have any important documents, if not, no problem leave it and shutdown your
computer.
8. Re-install your Windows XP service pack 2
hope your problem may solve.....
Jun 21, 2009 | Toshiba Tecra S1 Notebook
Failure to load windows?
Turn on the computer.
Press F8 every few seconds.
You should get a screen with a ton of choices.
Choose Safe Mode with Command Prompt.
Write me back when you're this far.
Feb 26, 2009 | HP PAVILLION DV6841TX PC Desktop
MY COMPAQ PRESARIO 5000 WILL NOT OPEN WINDOWS XP.
Does your desktop comeup and give any time before it shutdowns, say 1 minute or something like that,
You can log into safe mode and do system restore by pressing F8 once you power on the computer, but you need to keep on pressing till you see the safe mode option.
Jan 11, 2009 | Compaq Presario 5000 PC Desktop
Toshiba equium l20-197 booting
Chances are that it is a driver problem, try booting in safe mode by pressing f8 during the initial bot up process and selecting safe mode, with or without networking, if your systems goes in to windows then you have a drive issue, as safe mode loads with only the basic drivers needed to run windows, hope that helps
Dec 14, 2008 | Toshiba Equium 100 PC Desktop
Windows vista on Accer aspire 5315 reboots over and over
Try starting in safe mode (press f8 on start up) once in safe mode use system restore to restore your operating system to a earlier point.
For XP
Start - programs - accessories - system tools - system restore.
For Vista
Start - all programs - maintenance - backup and restore center
May 17, 2008 | Acer Aspire 5315 Notebook
My computer starts but before booting it shuts down.
You may have lost part of your windows program. If you have a system restore disk, you can run a system restore and probably fix your problem.
Some of your windows files have gotten deleted. When windows gets to this point all windows knows to do is restart. A virus can cause this problem.
Stargazer
Mar 16, 2008 | Gateway 310S (2900621) PC Desktop
Computers & Internet Logo
David Payne
David Payne
